Warning message
WS-X6516A-GBIC in 6509-E is PWRDOWN and Fabric channel errors
Nov 25th, 2013
I have a "WS-X6516A-GBIC" on slot 1 and it just failed, we have reseated it and enabled it via cli but it still doesn't work. The only thing that i haven't tried was to insert it on a different slot. I hope you guys can help me.
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI8, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
------------------ show module ------------------
Mod Ports Card Type                              Model              Serial No.
  1   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL1002A6VE
  2   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL091387CJ
  3   48  48-port 10/100 mb RJ45                 WS-X6148-RJ-45     SAL0738LNC1
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1128U6VM
  6   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-45AF  SAL1531L56S
  7   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL1210J4N2
  9   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1026SR2W
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0005.7441.fdbc to 0005.7441.fdcb   4.2   7.2(1)       12.2(33)SXI8 PwrDown
  2  0013.7f4d.5e50 to 0013.7f4d.5e7f  10.1   7.2(1)       12.2(33)SXI8 Ok
  3  000d.bc1e.b864 to 000d.bc1e.b893   1.3   5.4(2)       12.2(33)SXI8 Ok
  5  0013.c347.6328 to 0013.c347.632b   5.2   8.5(2)       12.2(33)SXI8 Ok
  6  30e4.dbef.3b40 to 30e4.dbef.3b6f   4.1   8.4(1)       12.2(33)SXI8 Ok
  7  001e.7afa.ecd0 to 001e.7afa.ecff   1.7   8.4(1)       12.2(33)SXI8 Ok
  9  0018.1942.0590 to 0018.1942.05bf   3.1   8.3(1)       12.2(33)SXI8 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL09391RLS  2.1    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL09391SRB  2.3    Ok
  6  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1531LGXW  2.5    Ok
  9  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1028UJTP  1.5    Ok
Mod  Online Diag Status
  1  Not Applicable
  2  Pass
  3  Pass
  5  Pass
  6  Pass
  7  Pass
  9  Pass
------------------ show power ------------------
system power redundancy mode = redundant
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power used =      1221.36 Watts (29.08 Amps @ 42V)
system power available = 1549.80 Watts (36.90 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      150.36  3.58  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6516A-GBIC      152.04  3.62     -     -     on    off (Fabric channel errors)
2    WS-X6548-GE-TX      125.16  2.98   125.16  2.98  on    on
3    WS-X6148-RJ-45      100.38  2.39   100.38  2.39  on    on
5    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
6    WS-X6148A-GE-45AF   282.24  6.72   282.24  6.72  on    on
7    WS-X6148A-GE-TX     105.00  2.50   105.00  2.50  on    on
9    WS-X6148-45AF       107.94  2.57   107.94  2.57  on    on
                        Inline         Inline         Inline         Inline
                        Pwr-Requested  Pwr-Allocated  Local-Pwr-Pool Power
Slot Card-Type          Watts   A @42V Watts   A @42V Watts   A @42V Status
6    WS-F6K-48-AF          -     -        -     -       34.61  0.82  On
9    WS-F6K-FE48-AF        -     -        -     -       34.61  0.82  On
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              1221.36 Watts (29.08 Amps @ 42V)
system auxiliary power used =            0 Watt
                        Inline         Inline-Pwr     Inline-Pwr     VDB
                        Pwr-Limit      Used-Thru-Pri  Used-Thru-Aux  Aux-Pwr
Slot Card-Type          Watts   A @42V Watts   A @42V Watts   A @42V Capable
6    WS-F6K-48-AF        850.08 20.24    34.44  0.82     -     -     No
9    WS-F6K-FE48-AF      840.00 20.00    34.44  0.82     -     -     No
Totals:                                  68.88  1.64     -     -
Jon Marshall Mon, 11/25/2013 - 08:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try a different slot ie. slot 4 is available in your chassis. If that works then it is likely to be a problem with the actual chassis itself.
Jon
Leo Laohoo Mon, 11/25/2013 - 12:54
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
To add what Jon has stated, post the "sh log".  The diagnostics should reveal a lot of useful information.
