TGW 3.5 on Linux
Wayne Knight
Thought I would start a new thread...
I have installed TGW on linux and can access the web gui via the same box but cannot access it beyond itself. Is there something I am missing.
Address of collector is 192.168.10.10 listening on ports 80 and 443
tcp        0      0 ::ffff:192.168.10.10:80      :::*                        LISTEN
tcp        0      0 ::ffff:192.168.10.10:443     :::*                        LISTEN
I can see its doing IPV6 to 4 feature in the netstat table, see below.
tcp        0      0 0.0.0.0:111                 0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:56598               0.0.0.0:*                   LISTEN
tcp        0      0 127.0.0.1:631               0.0.0.0:*                   LISTEN
tcp        0      0 127.0.0.1:25                0.0.0.0:*                   LISTEN
tcp        0      0 127.0.0.1:32000             0.0.0.0:*                   LISTEN
tcp        0     52 192.168.10.10:22             10.10.10.10:55506         ESTABLISHED
tcp        0      0 127.0.0.1:32000             127.0.0.1:31000             ESTABLISHED
tcp        0      0 :::111                      :::*                        LISTEN
tcp        0      0 :::22                       :::*                        LISTEN
tcp        0      0 ::1:631                     :::*                        LISTEN
tcp        0      0 :::60381                    :::*                        LISTEN
tcp        0      0 :::5001                     :::*                        LISTEN
tcp        0      0 ::ffff:127.0.0.1:31000      ::ffff:127.0.0.1:32000      ESTABLISHED
Wayne
Bryan Williams
Hi Wayne, I had the same problem in my lab.  Engineering fixed the problem and their explanation was:
"Etc/hosts was missing the ipaddress and hostname entry."
I'm still waiting for an explanation, so I'm not sure if the dependency is simply name resolution or if the hosts file is a hard requirement.
I'll test various combinations in the lab later and update this post.
Hi Bryan
I couldn't start the service without setting the /etc/hosts file, but found the fault. It was not IPv6 related as disabling this did not resolve the issue. It was iptables blocking the port 80 connection.
Modifying /etc/sysconfig/iptables to allow 80 and 443 now works remotely.
Next issue...
I cannot test the connection or register tgw, I get the following error in the logs
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: No trusted certificate found
Wayne
Yes, the first release of 3.5 had a problem with the production certificate included in the download.
Engineering released a new version late yesterday with a fix. Please download the new version and re-install.
Alternatively, you can clear that error by deleting lb_truststore.jks from tg/resources/security and restarting the process.  I'll provide the full path in a moment.  But I would recommend installing the latest version.
