11-25-2013 02:09 PM - edited 03-07-2019 04:46 PM
Hello All,
I have finished installing an license upgrade from ipbase to ipservices in a 3560X switch. Executing the show license command indicates
that the "License State: Active: In Use" is set for ipservices.
The reason for the upgrade is so that I will be able to do Inter-VLAN IP Multicast Routing. How do I determine that I have the proper commands to do this?
Running the show ? command does not show what I am looking for; example ip pim dense-mode?
Thanks for any help.
Jeff
Solved! Go to Solution.
11-27-2013 07:43 AM
11-25-2013 02:12 PM
Jeff
try these commands -
switch(config)# ip multicast-routing
if it accepts that then change to an SVI on your switch and try -
switch(config-if)# ip pim ?
Jon
11-25-2013 11:52 PM
Pls use this command
sdm prefer lanbase-routing
reload the switch & check
Rate if helpful
BR/Subhojit
11-26-2013 08:54 AM
Hello
I checked my sdm setting and it is set to "desktop default". Are you saying that commanding the switch to "sdm prefer routing"
will enable me to use Inter-VLAN Multicast Routing?
Thanks..
Jeff
11-26-2013 12:09 PM
Jeff
There are certain things such as PBR that do require you to change to the routing template but i'm not aware of this requirement for multicast. You may want to depending on how many routes you are going to have. See the table in this link for details -
Are the multicast commands i posted not available ?
Jon
11-27-2013 06:27 AM
Hi Jon
I have a small LAN setup and have spent a great amount of time working with VLANs and with Multicast VLAN Registration (MVR). At this time there is no routing outside my present setup but at some time there will be. My goal is to be able to work with Inter-VLAN IP Multicast Routing and to prove the concept can work in our environment.
Unfortuntaly, I did not have the correct switches to explore this. We finally got a 3560x switch upgraded with the IPservices License and just got it installed. However, and this what I am trying to find out, is that I do not have the confidenene that I have everything to do the routing now.
I know in my previous dicussions in the past before the upgrade that I needed the license upgrade and PIM to do the routing.
When I try to enter PIM on the switch, the command is not recognized. What am I missing and how do I check that the switch is ready to go?
Thanks for any help!
Jeff
11-27-2013 06:30 AM
Jeff
On the 3560
switch(config)# ip ?
do you see an option for multicast-routing
if yes
change to an SVI ie.
switch(config)# int vlan
do you see options for different PIM types ?
Jon
11-27-2013 07:09 AM
Hi Jon
Thats what I needed to see!!! I have sparse-dense-mode, sparse-mode and dense-mode among others.
Was that all there was to it?
Thanks.
Jeff
11-27-2013 07:43 AM
Jeff
Pretty much, yes.
Jon
11-27-2013 07:53 AM
Thanks, Jon
Have a good Holiday!
Jeff
