Warning message
How to shutdown vlan in layer2
Answered Question
Nov 25th, 2013
How to shutdown vlan in layer2 ? Thanks in advance.
I've done it using "shutdown" command. but still it is showing active in "show vlan".
switch0(config)#interface vlan 2
switch0(config-if)#
%LINK-5-CHANGED: Interface Vlan2, changed state to up
switch0(config-if)#shutdown
%LINK-5-CHANGED: Interface Vlan2, changed state to administratively down
switch0(config-if)#end
switch0#
%SYS-5-CONFIG_I: Configured from console by console
switch0#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gig1/1, Gig1/2
2    VLAN0002                         active
Chandu
Correct Answer by Sandeep Choudhary about 3 years 8 months ago
HI Chandu,
PT is more then enough for CCNA.
Dont worry just study the basic conecpts and do some lab practice on PT.
If you need any more labs then just PM me.
HI Chandu,
Are you using PT ????
PT dont have this command.
HI Chandu,
vlan 100, shutdown, and  interface vlan 100, shutdown
Shutting down the interface  vlan 2 disables the Layer 3 interface for that VLAN on the switch.  This means hosts will still be able to communicate WITHIN the VLAN  (Layer 2) but can not be routed off of the subnet.
Shutting  down the VLAN (vlan 2) disables Layer 2 switching of that VLAN on the  switch. This will effectively turn off all layer 2 switching on the  VLAN (preventing all communication).
Dont forget to rate helpful posts.
Overall Rating: 5 (3 ratings)
Correct Answer
Sandeep Choudhary Mon, 11/25/2013 - 22:50
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Chandu,
chandra_rc16 Mon, 11/25/2013 - 22:55
Sandeep,
I'm not seeing the any options here.
switch0(config)#vlan 2 ?
Chandu
Sandeep Choudhary Mon, 11/25/2013 - 23:01
    2017 Wireless
Hi chandu,
Config t
Vlan 2
Shut
chandra_rc16 Mon, 11/25/2013 - 23:10
Still.
switch0(config-vlan)#?
VLAN configuration commands:
  exit  Apply changes, bump revision number, and exit mode
  name  Ascii name of the VLAN
  no    Negate a command or set its defaults
Correct Answer
Sandeep Choudhary Mon, 11/25/2013 - 23:25
    2017 Wireless
HI Chandu,
chandra_rc16 Mon, 11/25/2013 - 23:28
Yes it's PT. Whenever i face this type situation na... then i'll doubt whether will PT help me to pass CCNA because it is not having these type of some basic commands..
And i can't get a real equipment...
Chandu
Correct Answer
Sandeep Choudhary Mon, 11/25/2013 - 23:32
    2017 Wireless
HI Chandu,
chandra_rc16 Tue, 11/26/2013 - 02:41
What is the command? Subhojit .
I think even that also will not be there in PT.
Sandeep Choudhary Tue, 11/26/2013 - 02:45
    2017 Wireless
No vlan 2
state command not supported on PT.
glen.grant Tue, 11/26/2013 - 04:57
  If these commands don't show up its a packet tracer problem .  This is a known IOs command that's been around for many years.
conf t
vlan 10
shutdown
chandra_rc16 Tue, 11/26/2013 - 05:32
There is no shutdown command here:
