Warning message
Configuring several VLANs on a Cisco 881
Nov 27th, 2013
I already have VLAN 1 configured with DHCP and NAT/PAT working properly.
The router has the WAN port connected to the Internet, and the Fa 0 connected to the LAN.
Now I define interface vlan 2 with a new address for a new IP range, and a new DHCP pool.
Now I use the same port (fa 0) as trunk, so I can use both VLANs there.
Is this apporach correct, or should I use two interfaces as access ports, one for VLAN1 and other for VLAN2?
Thank you in advance for your help!
Collin Clark Wed, 11/27/2013 - 11:44
  • Purple, 4500 points or more
Trunking is the correct approach. Using multiple switchports will work also, however I prefer trunking. It's not as easy to create loops with a single connection.   If you need more bandwidth and/or redundancy you can simply create a port channel and move multiple links into it.
Hope it helps.
gabrielblanco1 Wed, 11/27/2013 - 23:23
Hi and thank you for your answer.
That is what I did, but the Router 881 is a bit special and the ports for the LAN connection operate like a switch.
I have one port trunking, but the configuration is not like in a router, is like in a switch.
And all the links between the switches until the final destination are trunking as well.
Just the final switch has an access port for the VLAN2, where the device is, but it does not get contact with the router.
Might be the type of router? any configuration in the way through different switches?
If I get the solution I will post it, but would like some more tips
Thank you!
gabrielblanco1 Wed, 11/27/2013 - 23:42
I did check it.
I am wondering if it can be done without using two interfaces on the router. However I could try it.
I paste here part of my configuration
ip dhcp pool VLAN
   network 192.168.132.0 255.255.255.0
   default-router 192.168.132.1
   dns-server 195.159.0.100 195.159.0.200 8.8.8.8
   lease 30
ip dhcp pool VLAN2
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   lease 30
interface FastEthernet0
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface Vlan1
description LAN
ip address 192.168.132.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
ip nat inside
Thanks!
cadet alain Thu, 11/28/2013 - 03:02
Is vlan 2 getting a dhcp address? ---> sh ip dhcp binding
if not debug ip dhcp server packet to see if it receives the dhcp discover messages and what it does with them
if so  is vlan 2 host natted when going to internet ? ---> sh ip nat translation | i x.x.x.x where x.x.x.x is vlan 2 host
if not then post sh run | s nat and sh access-list
Alain
gabrielblanco1 Thu, 11/28/2013 - 03:07
I tried with static IP address as well. But did not work.
Regarding the NAT, I did not get to the point of checking it, since I do not have connection from the router. I cannot ping from the router to the host, and there is no NAT there
cadet alain Thu, 11/28/2013 - 03:49
So you can't ping your router from this host in vlan 2 ?
Can you provide a quick diagram of your topology and the entire running config from router as a  start
Alain
anish.antony Wed, 04/15/2015 - 00:49
Hi Guys
Did any one get the solution to this ?
i have a similar set up and would like to know if it works
LUKASZ KITA Thu, 11/28/2013 - 08:28
What about the sub interfaces?
Did you try it.
Sent from Cisco Technical Support Android App
Related Content
