Warning message
PfR -- Writing actual TX & RX rates to PfR Border Config . . . .
Nov 27th, 2013
This may not be the place for this specific question . . .
Regarding writing the actual TX and RX rates of a radio to the router -- I was writing to the bandwidth statement on the VLAN as a combined TX/RX throughput -- BUT shouldn't I really write directly to PfR?  Specifically to the bolded fields for TX and RX separately?:
2901_Rig_1#sho pfr mas bor det
Border           Status                UP/DOWN             AuthFail  Version  DOWN Reason
192.168.101.1    ACTIVE                UP       22:55:30          0  3.3
Vl2             EXTERNAL              UP
Vl3             EXTERNAL              UP
Vl5             EXTERNAL              UP
Vl9             EXTERNAL              UP
Gi0/1           INTERNAL              UP
External            Capacity      Max BW   BW Used    Load Status          Exit Id
Interface            (kbps)       (kbps)    (kbps)    (%)
Vl2             Tx    205500      133575         2       0 UP                    4
                 Rx                205500         3       0
Vl3             Tx     75000       48750         0       0 UP                    3
                 Rx                 75000         0       0
Vl5             Tx    150000       97500         0       0 UP                    2
                 Rx                150000         0       0
Vl9             Tx     65000      42250         0       0 UP                    1
                 Rx                 65000         0       0
Where would I write this though?   With EEM I can write to almost anything -- but can EEM write to that?
. . . not sure if EEM has opened the newer PfR yet for programming. . .
Tim
Joe Clarke Wed, 11/27/2013 - 12:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'll answer the EEM part, but you may want to post this question to the routing forum.  EEM can "write" to anything that exposes a CLI or SNMP read-write (or read-create) object.  If PfR makes these attributes available in the config, then you can use EEM to adjust the config for your desired values.  There is no PfR-specific API for EEM.
