IPSEC packets are not encrypted
Answered Question
Nov 27th, 2013
Hello (and Happy Thanksgiving to those in the USA),
We recently swapped our ASA and re-applied the saved config to the new device. There is a site-to-site VPN that works and a remote client VPN that does not. We use some Cisco VPN clients and some Shrew Soft VPN clients.I've compared the config of the new ASA to that of the old ASA and I cannot find any differences (but the remote client VPN was working on the old ASA). The remote clients do connect and a tunnel is established but they are unable to pass traffic. Systems on the network where the ASA is located are able to access the internet.
Output of sho crypto isakmp sa (ignore peer #1, that is the working site-to-site VPN)
   Active SA: 2
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA d
Total IKE SA: 2
1   IKE Peer: xx.168.155.98
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_ACTIVE
2   IKE Peer: xx.211.206.48
    Type    : user            Role    : responder
    Rekey   : no              State   : AM_ACTIVE
Output of sho crypto ipsec sa (info regarding site-to-site VPN removed). Packets are decrypted but not encrypted.
    Crypto map tag: SYSTEM_DEFAULT_CRYPTO_MAP, seq num: 65535, local addr: publi
c-ip
      local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
      remote ident (addr/mask/prot/port): (10.20.1.100/255.255.255.255/0/0)
      current_peer: xx.211.206.48, username: me
      dynamic allocated peer ip: 10.20.1.100
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 20, #pkts decrypt: 20, #pkts verify: 20
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: public-ip/4500, remote crypto endpt.: xx.211.206.48/4
500
      path mtu 1500, ipsec overhead 82, media mtu 1500
      current outbound spi: 7E0BF9B9
      current inbound spi : 41B75CCD
    inbound esp sas:
      spi: 0x41B75CCD (1102535885)
         transform: esp-aes esp-sha-hmac no compression
         in use settings ={RA, Tunnel,  NAT-T-Encaps, }
         slot: 0, conn_id: 16384, crypto-map: SYSTEM_DEFAULT_CRYPTO_MAP
         sa timing: remaining key lifetime (sec): 28776
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
      spi: 0xC06BF0DD (3228299485)
         in use settings ={RA, Tunnel,  NAT-T-Encaps, Rekeyed}
         sa timing: remaining key lifetime (sec): 28774
         IV size: 16 bytes
         Anti replay bitmap:
          0x000003FF 0xFFF80001
    outbound esp sas:
      spi: 0x7E0BF9B9 (2114714041)
         IV size: 16 bytes
         Anti replay bitmap:
      spi: 0xCBF945AC (3422111148)
         sa timing: remaining key lifetime (sec): 28772
         IV size: 16 bytes
         Anti replay bitmap:
Config from ASA
: Saved
: Written by me at 19:56:37.957 pst Tue Nov 26 2013
ASA Version 8.2(4)
hostname mfw01
domain-name company.int
enable password xxx encrypted
passwd xxx encrypted
names
name xx.174.143.97 cox-gateway description cox-gateway
name 172.16.10.0 iscsi-network description iscsi-network
name 192.168.1.0 legacy-network description legacy-network
name 10.20.50.0 management-network description management-network
name 10.20.10.0 server-network description server-network
name 10.20.20.0 user-network description user-network
name 192.168.1.101 private-em-imap description private-em-imap
name 10.20.10.2 private-exchange description private-exchange
name 10.20.10.3 private-ftp description private-ftp
name 192.168.1.202 private-ip-phones description private-ip-phones
name 10.20.10.6 private-kaseya description private-kaseya
name 192.168.1.2 private-mitel-3300 description private-mitel-3300
name 10.20.10.1 private-pptp description private-pptp
name 10.20.10.7 private-sharepoint description private-sharepoint
name 10.20.10.4 private-tportal description private-tportal
name 10.20.10.8 private-xarios description private-xarios
name 192.168.1.215 private-xorcom description private-xorcom
name xx.174.143.99 public-exchange description public-exchange
name xx.174.143.100 public-ftp description public-ftp
name xx.174.143.101 public-tportal description public-tportal
name xx.174.143.102 public-sharepoint description public-sharepoint
name xx.174.143.103 public-ip-phones description public-ip-phones
name xx.174.143.104 public-mitel-3300 description public-mitel-3300
name xx.174.143.105 public-xorcom description public-xorcom
name xx.174.143.108 public-remote-support description public-remote-support
name xx.174.143.109 public-xarios description public-xarios
name xx.174.143.110 public-kaseya description public-kaseya
name xx.174.143.111 public-pptp description public-pptp
name 192.168.2.0 Irvine_LAN description Irvine_LAN
name xx.174.143.98 public-ip
name 10.20.10.14 private-RevProxy description private-RevProxy
name xx.174.143.107 public-RevProxy description Public-RevProxy
name 10.20.10.9 private-XenDesktop description private-XenDesktop
name xx.174.143.115 public-XenDesktop description public-XenDesktop
name 10.20.1.1 private-gateway description private-gateway
name 192.168.1.96 private-remote-support description private-remote-support
interface Ethernet0/0
nameif public
security-level 0
ip address public-ip 255.255.255.224
interface Ethernet0/1
speed 100
duplex full
nameif private
security-level 100
ip address private-gateway 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.0.1 255.255.255.0
management-only
ftp mode passive
clock timezone pst -8
clock summer-time PDT recurring
dns server-group DefaultDNS
domain-name mills.int
object-group service ftp
service-object tcp eq ftp
service-object tcp eq ftp-data
object-group service DM_INLINE_SERVICE_1
group-object ftp
service-object udp eq tftp
object-group service DM_INLINE_TCP_1 tcp
port-object eq 40
port-object eq ssh
object-group service web-server
service-object tcp eq www
service-object tcp eq https
object-group service DM_INLINE_SERVICE_2
service-object tcp eq smtp
group-object web-server
object-group service DM_INLINE_SERVICE_3
service-object tcp eq ssh
object-group service kaseya
service-object tcp eq 4242
service-object tcp eq 5721
service-object tcp eq 8080
service-object udp eq 5721
object-group service DM_INLINE_SERVICE_4
group-object kaseya
object-group service DM_INLINE_SERVICE_5
service-object gre
service-object tcp eq pptp
object-group service VPN
service-object gre
service-object esp
service-object ah
service-object udp eq 4500
service-object udp eq isakmp
object-group network MILLS_VPN_VLANS
network-object 10.20.1.0 255.255.255.0
network-object server-network 255.255.255.0
network-object user-network 255.255.255.0
network-object management-network 255.255.255.0
network-object legacy-network 255.255.255.0
object-group service InterTel5000
service-object tcp range 3998 3999
service-object tcp range 6800 6802
service-object udp eq 20001
service-object udp range 5004 5007
service-object udp range 50098 50508
service-object udp range 6604 7039
service-object udp eq bootpc
service-object tcp eq 4000
service-object tcp eq 44000
service-object tcp eq 5566
service-object udp eq 5567
service-object udp range 6004 6603
service-object tcp eq 6880
object-group service DM_INLINE_SERVICE_6
service-object icmp
service-object tcp eq 2001
service-object tcp eq 2004
service-object tcp eq 2005
object-group service DM_INLINE_SERVICE_7
service-object icmp
group-object InterTel5000
object-group service DM_INLINE_SERVICE_8
service-object icmp
object-group service RevProxy tcp
description RevProxy
port-object eq 5500
object-group service XenDesktop tcp
description Xen
port-object eq 8080
port-object eq 2514
port-object eq 2598
port-object eq 27000
port-object eq 7279
port-object eq 8000
port-object eq citrix-ica
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_8 any host public-ip
access-list public_access_in extended permit object-group VPN any host public-ip
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_7 any host public-ip-phones
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_1 any host public-ftp
access-list public_access_in extended permit tcp any host public-xorcom object-group DM_INLINE_TCP_1
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_2 any host public-exchange
access-list public_access_in extended permit tcp any host public-RevProxy object-group RevProxy
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_3 any host public-remote-support
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_6 any host public-xarios
access-list public_access_in extended permit object-group web-server any host public-sharepoint
access-list public_access_in extended permit object-group web-server any host public-tportal
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_4 any host public-kaseya
access-list public_access_in extended permit object-group DM_INLINE_SERVICE_5 any host public-pptp
access-list public_access_in extended permit ip any host public-XenDesktop
access-list private_access_in extended permit icmp any any
access-list private_access_in extended permit ip any any
access-list VPN_Users_SplitTunnelAcl standard permit server-network 255.255.255.0
access-list VPN_Users_SplitTunnelAcl standard permit user-network 255.255.255.0
access-list VPN_Users_SplitTunnelAcl standard permit management-network 255.255.255.0
access-list VPN_Users_SplitTunnelAcl standard permit 10.20.1.0 255.255.255.0
access-list VPN_Users_SplitTunnelAcl standard permit legacy-network 255.255.255.0
access-list private_nat0_outbound extended permit ip object-group MILLS_VPN_VLANS Irvine_LAN 255.255.255.0
access-list private_nat0_outbound extended permit ip object-group MILLS_VPN_VLANS 10.20.1.96 255.255.255.240
access-list private_nat0_outbound extended permit ip object-group MILLS_VPN_VLANS 10.90.2.0 255.255.255.0
access-list public_1_cryptomap extended permit ip object-group MILLS_VPN_VLANS Irvine_LAN 255.255.255.0
access-list public_2_cryptomap extended permit ip object-group MILLS_VPN_VLANS 10.90.2.0 255.255.255.0
pager lines 24
logging enable
logging list Error-Events level warnings
logging monitor warnings
logging buffered warnings
logging trap warnings
logging asdm warnings
logging mail warnings
logging host private private-kaseya
logging permit-hostdown
logging class auth trap alerts
mtu public 1500
mtu private 1500
mtu management 1500
ip local pool VPN_Users 10.20.1.100-10.20.1.110 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (public) 101 interface
nat (private) 0 access-list private_nat0_outbound
nat (private) 101 0.0.0.0 0.0.0.0
nat (management) 101 0.0.0.0 0.0.0.0
static (private,public) public-ip-phones private-ip-phones netmask 255.255.255.255 dns
static (private,public) public-ftp private-ftp netmask 255.255.255.255 dns
static (private,public) public-xorcom private-xorcom netmask 255.255.255.255 dns
static (private,public) public-exchange private-exchange netmask 255.255.255.255 dns
static (private,public) public-RevProxy private-RevProxy netmask 255.255.255.255 dns
static (private,public) public-remote-support private-remote-support netmask 255.255.255.255 dns
static (private,public) public-xarios private-xarios netmask 255.255.255.255 dns
static (private,public) public-sharepoint private-sharepoint netmask 255.255.255.255 dns
static (private,public) public-tportal private-tportal netmask 255.255.255.255 dns
static (private,public) public-kaseya private-kaseya netmask 255.255.255.255 dns
static (private,public) public-pptp private-pptp netmask 255.255.255.255 dns
static (private,public) public-XenDesktop private-XenDesktop netmask 255.255.255.255 dns
access-group public_access_in in interface public
access-group private_access_in in interface private
route public 0.0.0.0 0.0.0.0 cox-gateway 1
route private server-network 255.255.255.0 10.20.1.254 1
route private user-network 255.255.255.0 10.20.1.254 1
route private management-network 255.255.255.0 10.20.1.254 1
route private iscsi-network 255.255.255.0 10.20.1.254 1
route private legacy-network 255.255.255.0 10.20.1.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
ldap attribute-map admin-control
  map-name  comment Privilege-Level
ldap attribute-map allow-dialin
  map-name  msNPAllowDialin IETF-Radius-Class
  map-value msNPAllowDialin FALSE NOACCESS
  map-value msNPAllowDialin TRUE IPSecUsers
ldap attribute-map mills-vpn_users
  map-value msNPAllowDialin True IPSecUsers
ldap attribute-map network-admins
  map-name  memberOf IETF-Radius-Service-Type
  map-value memberOf FALSE NOACCESS
  map-value memberOf "Network Admins" 6
dynamic-access-policy-record DfltAccessPolicy
aaa-server Mills protocol nt
aaa-server Mills (private) host private-pptp
nt-auth-domain-controller ms01.mills.int
aaa-server Mills_NetAdmin protocol ldap
aaa-server Mills_NetAdmin (private) host private-pptp
server-port 389
ldap-base-dn ou=San Diego,dc=mills,dc=int
ldap-group-base-dn ou=San Diego,dc=mills,dc=int
ldap-scope subtree
ldap-naming-attribute cn
ldap-login-password *
ldap-login-dn cn=asa,ou=Service Accounts,ou=San Diego,dc=mills,dc=int
server-type microsoft
ldap-attribute-map mills-vpn_users
aaa-server NetworkAdmins protocol ldap
aaa-server NetworkAdmins (private) host private-pptp
ldap-scope subtree
ldap-attribute-map network-admins
aaa-server ADVPNUsers protocol ldap
aaa-server ADVPNUsers (private) host private-pptp
ldap-scope subtree
aaa authentication enable console ADVPNUsers LOCAL
aaa authentication http console ADVPNUsers LOCAL
aaa authentication serial console ADVPNUsers LOCAL
aaa authentication telnet console ADVPNUsers LOCAL
aaa authentication ssh console ADVPNUsers LOCAL
http server enable
http 0.0.0.0 0.0.0.0 management
http 0.0.0.0 0.0.0.0 public
http 0.0.0.0 0.0.0.0 private
snmp-server host private private-kaseya poll community ***** version 2c
snmp-server location Mills - San Diego
snmp-server contact Mills Assist
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp private
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map public_map 1 match address public_1_cryptomap
crypto map public_map 1 set pfs
crypto map public_map 1 set peer xx.168.155.98
crypto map public_map 1 set transform-set ESP-3DES-MD5 ESP-AES-128-SHA
crypto map public_map 1 set nat-t-disable
crypto map public_map 1 set phase1-mode aggressive
crypto map public_map 2 match address public_2_cryptomap
crypto map public_map 2 set pfs group5
crypto map public_map 2 set peer xx.181.134.141
crypto map public_map 2 set transform-set ESP-AES-128-SHA
crypto map public_map 2 set nat-t-disable
crypto map public_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map public_map interface public
crypto isakmp enable public
crypto isakmp policy 1
authentication pre-share
encryption aes
hash sha
group 5
lifetime 86400
crypto isakmp policy 10
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 1
lifetime 28800
telnet 0.0.0.0 0.0.0.0 private
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 public
ssh 0.0.0.0 0.0.0.0 private
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 5
console timeout 0
dhcpd address 192.168.0.2-192.168.0.254 management
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp authenticate
ntp server 216.129.110.22 source public
ntp server 173.244.211.10 source public
ntp server 24.124.0.251 source public prefer
webvpn
enable public
svc enable
group-policy NOACCESS internal
group-policy NOACCESS attributes
vpn-simultaneous-logins 0
vpn-tunnel-protocol svc
group-policy IPSecUsers internal
group-policy IPSecUsers attributes
wins-server value 10.20.10.1
dns-server value 10.20.10.1
vpn-tunnel-protocol IPSec
password-storage enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN_Users_SplitTunnelAcl
default-domain value mills.int
address-pools value VPN_Users
group-policy Irvine internal
group-policy Irvine attributes
username admin password Kra9/kXfLDwlSxis encrypted
tunnel-group VPN_Users type remote-access
tunnel-group VPN_Users general-attributes
address-pool VPN_Users
authentication-server-group Mills_NetAdmin
default-group-policy IPSecUsers
tunnel-group VPN_Users ipsec-attributes
pre-shared-key *
tunnel-group xx.189.99.114 type ipsec-l2l
tunnel-group xx.189.99.114 general-attributes
default-group-policy Irvine
tunnel-group xx.189.99.114 ipsec-attributes
pre-shared-key *
tunnel-group xx.205.23.76 type ipsec-l2l
tunnel-group xx.205.23.76 general-attributes
tunnel-group xx.205.23.76 ipsec-attributes
pre-shared-key *
tunnel-group xx.168.155.98 type ipsec-l2l
tunnel-group xx.168.155.98 general-attributes
tunnel-group xx.168.155.98 ipsec-attributes
pre-shared-key *
class-map global-class
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global-policy
class global-class
  inspect dns
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
service-policy global-policy global
privilege cmd level 3 mode exec command perfmon
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command packet-tracer
privilege show level 5 mode exec command import
privilege show level 5 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command asp
privilege show level 3 mode exec command cpu
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command vlan
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command ipv6
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command eigrp
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command wccp
privilege show level 3 mode exec command webvpn
privilege show level 3 mode exec command module
privilege show level 3 mode exec command uauth
privilege show level 3 mode exec command compression
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
privilege cmd level 3 mode configure command failover
privilege clear level 3 mode configure command logging
privilege clear level 3 mode configure command arp
privilege clear level 3 mode configure command crypto
privilege clear level 3 mode configure command aaa-server
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:5d5c963680401d150bee94b3c7c85f7a
Maybe my eyes are glazing over from looking at this for too long. Does anything look wrong? Maybe I missed a command that would not show up in the config?
Thanks in advance to all who take a look.
Correct Answer by Marius Gunnerud about 3 years 8 months ago
We see that the echo request is sent out the inerface but there is no echo reply.  This looks to be a routing issue between the ASA and the host you are trying to ping.  Could you check the routing so that traffic destined for 10.20.1.0 network is routed toward the ASA.  If there is no other routing device make sure that the default gateway is correct on the host you ate trying to reach.
if you are trying to ping a windows machine make sure windows firewall is off or allows ICMP.
Please remember to rate and select a xorrect answer
Overall Rating: 5 (1 ratings)
Marius Gunnerud Thu, 11/28/2013 - 00:28
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
Could you run a packet capture when initiating a connection from the host.  If at possible you can amend the ACL to match the VPN client ACL more exactly.
access-list cap-inside extended permit ip 10.20.1.96 255.255.255.240 any
access-list cap-inside extended permit ip any 10.20.1.96 255.255.255.240
capture capin interface inside access-list cap-inside
show capture capin
Please rate all helpful posts
Kris McCormick Fri, 11/29/2013 - 09:52
Marius,
I connected via my VPN client at home and pinged a remote server, attempted to RDP by name and then attempted to RDP by IP address. All were unsuccessful. Here is the packet capture:
72 packets captured
   1: 09:44:06.304671 10.20.1.100.137 > 10.20.10.1.137:  udp 68
   2: 09:44:06.304885 10.20.1.100.54543 > 10.20.10.1.53:  udp 34
   3: 09:44:07.198384 10.20.1.100.51650 > 10.20.10.1.53:  udp 32
   4: 09:44:07.300353 10.20.1.100.54543 > 10.20.10.1.53:  udp 34
   5: 09:44:07.786504 10.20.1.100.137 > 10.20.10.1.137:  udp 68
   6: 09:44:07.786671 10.20.1.100.137 > 10.20.10.1.137:  udp 68
   7: 09:44:07.786855 10.20.1.100.137 > 10.20.10.1.137:  udp 68
   8: 09:44:08.198399 10.20.1.100.51650 > 10.20.10.1.53:  udp 32
   9: 09:44:09.282608 10.20.1.100.61328 > 10.20.10.1.53:  udp 32
  10: 09:44:09.286667 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  11: 09:44:09.286926 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  12: 09:44:09.287201 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  13: 09:44:09.300491 10.20.1.100.54543 > 10.20.10.1.53:  udp 34
  14: 09:44:10.199193 10.20.1.100.51650 > 10.20.10.1.53:  udp 32
  15: 09:44:10.282150 10.20.1.100.61328 > 10.20.10.1.53:  udp 32
  16: 09:44:11.286865 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  17: 09:44:12.302993 10.20.1.100.61328 > 10.20.10.1.53:  udp 32
  18: 09:44:12.785054 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  19: 09:44:13.301101 10.20.1.100.54543 > 10.20.10.1.53:  udp 34
  20: 09:44:14.204029 10.20.1.100.51650 > 10.20.10.1.53:  udp 32
  21: 09:44:14.287323 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  22: 09:44:14.375331 10.20.1.100 > 10.20.10.1: icmp: echo request
  23: 09:44:16.581589 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  24: 09:44:18.083842 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  25: 09:44:18.199879 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  26: 09:44:19.224063 10.20.1.100 > 10.20.10.1: icmp: echo request
  27: 09:44:19.582367 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  28: 09:44:19.704019 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  29: 09:44:20.288193 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  30: 09:44:21.200307 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  31: 09:44:21.786321 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  32: 09:44:23.289535 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  33: 09:44:24.204777 10.20.1.100 > 10.20.10.1: icmp: echo request
  34: 09:44:29.219440 10.20.1.100 > 10.20.10.1: icmp: echo request
  35: 09:44:29.287460 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  36: 09:44:30.787617 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  37: 09:44:32.287887 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  38: 09:45:00.533816 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  39: 09:45:02.018019 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  40: 09:45:03.160239 10.20.1.100.52764 > 10.20.10.1.53:  udp 34
  41: 09:45:03.350354 10.20.1.100.53948 > 10.20.10.1.53:  udp 38
  42: 09:45:03.521960 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  43: 09:45:04.158408 10.20.1.100.52764 > 10.20.10.1.53:  udp 34
  44: 09:45:04.344342 10.20.1.100.53948 > 10.20.10.1.53:  udp 38
  45: 09:45:06.160681 10.20.1.100.52764 > 10.20.10.1.53:  udp 34
  46: 09:45:06.358593 10.20.1.100.53948 > 10.20.10.1.53:  udp 38
  47: 09:45:10.159125 10.20.1.100.52764 > 10.20.10.1.53:  udp 34
  48: 09:45:10.345227 10.20.1.100.53948 > 10.20.10.1.53:  udp 38
  49: 09:45:14.550478 10.20.1.100.59402 > 10.20.10.1.53:  udp 32
  50: 09:45:15.536166 10.20.1.100.59402 > 10.20.10.1.53:  udp 32
  51: 09:45:17.546144 10.20.1.100.59402 > 10.20.10.1.53:  udp 32
  52: 09:45:21.882812 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  53: 09:45:23.379222 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  54: 09:45:24.893386 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  55: 09:45:41.550035 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  56: 09:45:43.029875 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  57: 09:45:44.541979 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  58: 09:46:10.767782 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  59: 09:46:12.261934 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  60: 09:46:13.776250 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  61: 09:46:19.848970 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  62: 09:46:20.113183 10.20.1.100.49751 > 10.20.10.7.3389: S 3288428077:3288428077(0) win 8192
  63: 09:46:21.331251 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  64: 09:46:22.831423 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  65: 09:46:23.101511 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  66: 09:46:23.123254 10.20.1.100.49751 > 10.20.10.7.3389: S 3288428077:3288428077(0) win 8192
  67: 09:46:24.591705 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  68: 09:46:26.115976 10.20.1.100.137 > 10.20.10.1.137:  udp 50
  69: 09:46:28.834276 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  70: 09:46:29.125817 10.20.1.100.49751 > 10.20.10.7.3389: S 3288428077:3288428077(0) win 8192
  71: 09:46:30.342816 10.20.1.100.137 > 10.20.10.1.137:  udp 68
  72: 09:46:31.840746 10.20.1.100.137 > 10.20.10.1.137:  udp 68
72 packets shown
Correct Answer
Marius Gunnerud Fri, 11/29/2013 - 10:12
    2017 Firewalling
Kris McCormick Fri, 11/29/2013 - 10:36
Marius,
You were correct. The interntal gateway behind the ASA is an Enterasys switch. I added this route:
ip route 10.20.1.96 255.255.255.240 10.20.1.1
Once added, I was able to connect to internal resources via the VPN client.
What is odd is that the Enterasys did not require this route before the hardware swap for us to access via the VPN client. Oh well, I am glad it is working now.
Thanks so much for the assistance!
Marius Gunnerud Fri, 11/29/2013 - 11:04
    2017 Firewalling
Glad you got it working :-)
