Router on a Stick Inter-Vlan
Answered Question
Nov 28th, 2013
  • Silver, 250 points or more
Router(config)#interface f0/0
Router(config-if)#no shutdown
Router(config)#interface f1/0
Router(config)#interface f0/0.1
Router(config-subif)#encapsulation dot1q 15
Router(config-subif)#ip address 192.168.15.1 255.255.255.0
Router(config-subif)#interface f0/0.2
Router(config-subif)#encapsulation dot1q 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
Switch1(config)#vlan 15
Switch1(config-vlan)#name SALES
Switch1(config-vlan)#vlan 20
Switch1(config-vlan)#name SUPPORT
Switch1(config)#interface fa0/1
Switch1(config)#switchport mode trunk
Switch1(config)#interface range fa1/1
Switch1(config-if)#no shutdown
Switch1(config-if)# switchport mode access
Switch1(config-if)# switchport access vlan 15
Switch1(config-if)#interface range fa2/1
Switch1(config-if)#switchport mode access
Switch1(config-if)# switchport access vlan 20
Switch2(config)#vlan 15
Switch2(config-vlan)#name SALES
Switch2(config-vlan)#vlan 20
Switch2(config-vlan)#name SUPPORT
Switch2(config)#interface fa0/1
Switch2(config)#switchport mode trunk
Switch2(config)#interface range fa1/1
Switch2(config-if)#no shutdown
Switch2(config-if)# switchport mode access
Switch2(config-if)# switchport access vlan 15
Switch2(config-if)#interface range fa2/1
Switch2(config-if)#switchport mode access
Switch2(config-if)# switchport access vlan 20
This is the Commands i used for 1 Router connected t o 2 Switches but it somehow i dont know it doesnt working :/.Im trying to add 2 Vlans + Default Vlan and connected it with class c /27 ip address Any help?
Posted by WebUser Charalampos Skeleton C'trattou from Cisco Support Community App
Correct Answer by Sandeep Choudhary about 3 years 8 months ago
As per your topology.
see this and match ur config:
Router
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 15
interface FastEthernet0/0.2
encapsulation dot1Q 20
Swicth 0
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
vlan 15
name SALES
vlan 20
name SUPPORT
Switch 2
vlan 15
name SALES
vlan 20
name SUPPORT
PC0
IP: 192.168.15.2
mask:255.255.255.0
GW:192.168.15.1
PC1
IP: 192.168.20.2
mask:255.255.255.0
GW:192.168.20.1
PC2
IP: 192.168.15.3
mask:255.255.255.0
GW:192.168.15.1
PC3
IP: 192.168.20.3
mask:255.255.255.0
GW:192.168.20.1
Hope it helps.
Overall Rating: 5 (1 ratings)
Sandeep Choudhary Thu, 11/28/2013 - 04:49
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Where u r connecting the 2nd switch on router because you are creating sub interfaces on fa0/0.
What exactly not working ???
What u want yo acheive ??
chandra_rc16 Thu, 11/28/2013 - 06:37
Is possible for you to the post the topology pic ?
or else
Can you make it clear with physical connection between the devices ?
Chandu
Julio Carvajal Sun, 12/01/2013 - 00:09
Do the computers already have a valid IP address, DNS value and Default gateway??
If yes, what happens if you ping the Router sub-interface IP address for the respective vlan??
Can you ping between computers on the same VLAN???
Can you provide the output of show interface trunk of both switches?
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Correct Answer
Sandeep Choudhary Sun, 12/01/2013 - 00:29
    2017 Wireless
Router
no ip address
duplex auto
speed auto
Swicth 0
vlan 15
name SALES
vlan 20
name SUPPORT
Switch 2
vlan 15
name SALES
vlan 20
name SUPPORT
PC0
IP: 192.168.15.2
mask:255.255.255.0
GW:192.168.15.1
PC1
IP: 192.168.20.2
mask:255.255.255.0
GW:192.168.20.1
PC2
IP: 192.168.15.3
mask:255.255.255.0
GW:192.168.15.1
PC3
IP: 192.168.20.3
mask:255.255.255.0
GW:192.168.20.1
Hope it helps.
sngashc1026 Sat, 11/30/2013 - 13:33
Are both the interfaces from Switch 1 going to the Router and to Switch 2 trunking? Your config shows only one port on Switch 1 statically configured as a trunk. Hope that helps
fb_webuser Sun, 12/01/2013 - 06:41
The topology on the image is a Router on A stick which is based on 1 router and 2 switches. Basically the 1 switch is connected with the router and the other one is connected to the switch which leads to a inter vlan routing. The commands i posted lead to an error to ping between the pcs.i used a class c ip address which are basically writing at the post. im gonna try san deep answer and see afterwards
Sandeep Choudhary Wed, 12/04/2013 - 03:45
    2017 Wireless
HI ,
Did u connect the right interface to switch.?
swicth interface should be in trunk mode which is connect to router.
chandra_rc16 Wed, 12/04/2013 - 06:54
Can you post the "show cdp neighbors" from three of those devices ?
Chandu
