Warning message
WAP321 - username post wizard
Endorsed Question
Nov 28th, 2013
After going through the wizard and setup a new password,  what is the username I should use? The wizard does not allow to input username.
HELP!!!
Cisco Endorsed by Eric Moyers
cchamorr about 2 years 6 months ago
After finishing the wizard you should have changed the password but the username will remain the same, so when you try to log into the unit the next time you should use cisco as the username and the new password that you just changed during the wizard
If that is not working, you will have to reset the wap and start again.
To reset the wap make sure that it is turn on and hold the reset button for over 30 seconds, then it should go back to the default settings and you can log back into it by going to 192.168.1.245 and entering cisco/cisco as your credentials.
I hope this helps
Overall Rating: 5 (1 ratings)
Leonardo Gonzaga Thu, 11/28/2013 - 06:49
And i'm also having dificulties doing the "reset to factory default" routine. Reset button for more than 10 seconds not working.
cchamorr Fri, 01/23/2015 - 12:04
  • Silver, 250 points or more
I hope this helps
Leonardo Gonzaga Tue, 03/31/2015 - 03:00
I got it to work. It was actually working all along. The problem was with Internet Explorer's inconsistent behaviour.
Use chrome.
Eric Moyers Tue, 03/31/2015 - 05:52
I am glad to hear that. Thank you for letting us know and for telling what you did to resolve. That will help other who may run into the same issue.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
