Warning message
how to configure wireless air sap 1602?default ip adress?
Nov 28th, 2013
Hi does anybody know what is the default ip adress for to enter the configuration web page of the access point
air sap 1602?
how do i configure it?
I just plug it to my router and would like to configure it so it can be usable and recognised in my network
thanks
Scott Fella Fri, 11/29/2013 - 04:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Use a console cable and connect it to the AP. Default IP is 10.0.0.1 I believe unless it gets an IP address from dhcp.
Rasika Nayanajith Fri, 11/29/2013 - 09:55
  • Purple, 4500 points or more
    2017 Wireless
Connect a console cable & get "show ip interface brief" output. That should tells you what is the IP assigned to your AP (BVI interface).
If your router gives DHCP & you just want to configure it for a SSID with pre-shared key, you can try some configuration like this.
hostname
dot11 ssid
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid
no shutdown
interface Dot11Radio1
ssid
no shutdown
interface BVI1
ip address dhcp
Rasika
**** Pls rate all useful responses *****
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
