Warning message
wifi can't access WLC
Answered Question
Nov 28th, 2013
hello
i have a question
i config a WLC 5508 and one LAP join it
now i connect the SSID
i can get the right ip address
i can ping another address
at the same time i can ping WLC and telenet WLC port 443 is OK
but i cant access the WLC web page
if i connect the local nic (....RJ-45 to my PC...i don't known how to say.....)
i can access WLC....
who can help me..?
Correct Answer by Sandeep Choudhary about 3 years 8 months ago
Just adding to Rasika...
If u can telnet WLC then please run this command to access via GUI.
config network mgmt-via-wireless enable
config network mgmt-via-dynamic-interface enable
Correct Answer by Rasika Nayanajith about 3 years 8 months ago
This is the default behavior & it blocks WLC mgt access via wireless.
If you want to change this, you can go in GUI  "Management -> Management Via Wireless -> enable "
Keep note that then all wireless users can get into this page (without knowing password they cannot do much), & as a security measure by default this is blocked.
Rasika
**** Pls rate all useful responses ****
Overall Rating: 5 (2 ratings)
Correct Answer
Rasika Nayanajith Thu, 11/28/2013 - 11:05
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Rasika
bo liu Thu, 11/28/2013 - 17:25
rasikanayanajith
thanks very much!
the WLC is not in the same subnet with wifi , so i can use ACL deny access but administrator wifi....
Correct Answer
Sandeep Choudhary Thu, 11/28/2013 - 11:26
    2017 Wireless
bo liu Thu, 11/28/2013 - 17:27
hi sandeep
thanks you for you reply
Trending Topics - Security & Network
