Warning message
AP clock
Answered Question
Nov 28th, 2013
hi,
does anyone know how to configure clock for all APs that assocated ? and keep the clock
Correct Answer by Leo Laohoo about 3 years 8 months ago
no that's incorrect.
I can go to each LWAP to do
Yes, you can configure the AP individually but you CANNOT save this config.  Reboot the AP and it will revert back to GMT/UTC.  This behaviour is normal.
The only way to see this in local time is to get a network monitoring tool like Prime Infrastructure.
Overall Rating: 4.8 (5 ratings)
Leo Laohoo Thu, 11/28/2013 - 16:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Autonomous IOS use SNTP.  So if you want to configure clock, try "sntp serve 1.2.3.4".
You may also want to configure your timzeone too.
kuan yang Thu, 11/28/2013 - 16:45
i should've mentioned for all LWAPs
is there a way for wlc to configure all LWAP?
Leo Laohoo Thu, 11/28/2013 - 16:59
  • Hall of Fame,
    2017 LAN, Wireless
All the APs clocks are expressed in GMT/UTC.  You can't change the timezone.
The WLC will control the aspect of the time on the AP.  The main thing you need to consider is the WLC must have a valid timesource.
kuan yang Thu, 11/28/2013 - 17:05
Hi Leo,
my problem is that, wlc is configured for say GMT9:30 and sync with ntp.
there are 200 APs in the network are default to UTC 0 time zone.
to make AP show correct time, i need to telnet to the AP and execute clock commands like :
MyAP0001#sh run | i clock
clock timezone CST 9 30
clock summer-time CDT recurring 1 Sun Oct 2:00 1 Sun Apr 2:00
i wonder if there is a way to configure all 200 APs together from WLC.
thank you
Leo Laohoo Thu, 11/28/2013 - 17:06
  • Hall of Fame,
    2017 LAN, Wireless
Nope.
AP will always show the correct time because the AP gets all the information from the WLC.
This is to be expected.
kuan yang Thu, 11/28/2013 - 17:08
the fact is:
wlc is showing in GMT9:30 time and AP is showing default UTC0 time
Leo Laohoo Thu, 11/28/2013 - 17:21
  • Hall of Fame,
    2017 LAN, Wireless
What timezone is the AP located?
Leo Laohoo Thu, 11/28/2013 - 17:31
  • Hall of Fame,
    2017 LAN, Wireless
GMT9:30
And what timezone is the WLC configured for?
kuan yang Thu, 11/28/2013 - 18:04
WLC is configured for GMT9:30
APs are left in default time configuration UTC0
and im wondering if i can do configuration from WLC to push out all APs to run on GMT9:30
Rasika Nayanajith Thu, 11/28/2013 - 18:13
  • Purple, 4500 points or more
    2017 Wireless
For lightweight APs you cannot set a timezone. So it is always shown in UTC time & that cannot be changed.
Rasika
**** Pls rate all useful responses ****
kuan yang Thu, 11/28/2013 - 18:16
I can go to each LWAP to do , im running versoon 7.4.110.0
ap09#sh ver | i IOS
Cisco IOS Software, C1520 Software (C1520-K9W8-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
ap09#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ap09(config)#clock timezone CST 9 30
ap09(config)#clock summer-time CDT recurring 1 Sun Oct 2:00 1 Sun Apr 2:00
ap09(config)#
ap09#sh clock
*12:45:59.403 CDT Fri Nov 29 2013
Rasika Nayanajith Thu, 11/28/2013 - 18:28
    2017 Wireless
But if you reboot this AP will your configuration remain ? I doubted,
You cannot save any local configurations you made on these AP since everythign is controlled by WLC
Rasika
kuan yang Thu, 11/28/2013 - 18:32
Hi Rasika,
so are you saying WLC cannot configure AP clocks?
if you notice, on AP CLI, i can save the clock to nvram. if clock is lost after power cycle, then this configuration is purely meaningless.
Rasika Nayanajith Thu, 11/28/2013 - 18:35
    2017 Wireless
Yes, you cannot set a timezone for APs via WLC. So AP will always shown in UTC time. So even if you change by locally configuring like above you configuration will be lost during a power cycle.
Are you having mesh image or are they purely local mode AP ?
Rasika
kuan yang Thu, 11/28/2013 - 18:39
it's mesh image on 1524SB.
AP09(config)#clock ?
  initialize   Initialize system clock on restart
  save         backup of clock with NVRAM
if you are right, above commands should be useless basically. i just like a confirmation if global AP clock configuration from WLC can or cannot be done.
Rasika Nayanajith Thu, 11/28/2013 - 18:46
    2017 Wireless
Cannot be done is the answer to this.
Rasika
kuan yang Thu, 11/28/2013 - 18:48
thanks man,
it's just a little confusion, IOS let me config and save to nvram but wont keep the config after reboot.
i will test when i can reboot an AP.
Rasika Nayanajith Thu, 11/28/2013 - 19:38
    2017 Wireless
Yes, test it yourself & let us know.. but do not keep a hope it will work..
Rasika
Correct Answer
Leo Laohoo Thu, 11/28/2013 - 18:38
  • Hall of Fame,
    2017 LAN, Wireless
Sandeep Choudhary Thu, 11/28/2013 - 22:12
    2017 Wireless
HI Kuan,
example shows how to manually set the system clock to 7:10 a.m. on November 29, 2013:
AP# clock set 07:10:00 29 November 2013
Fore more : How to configure time and date on AP manually,please visit this document:
https://supportforums.cisco.com/docs/DOC-4842
Dont forget to rate helpful posts.
kuan yang Sun, 12/01/2013 - 15:46
Hi Sandeep and all,
i know how to do to individual AP, but it's time comsuming to do on 200 APs.
Maybe i should request this features in furthere software: to configure AP clock from WLC.
thanks everyone, i have conclusion of this discussion.
to those who wants to know the answer:
you cannot configure LWAP clock from WLC.
you can config AP clock at telnet to LWAP CLI individually.
config "clock saving interval 8" and "no clock initialize nvram" do not make any difference after reboot.
the clock will default to UTC after reboot.
Rasika Nayanajith Sun, 12/01/2013 - 15:59
    2017 Wireless
You have come to a right conclusion.
Pls mark this question as anwered and rate any useful responses. That will help others to find answer to a similar query.
Rasika
