ASA DHCP relay feature
Dec 1st, 2013
Hi all ,
We have created our DHCP scopes on the firewall for our wireless users , now we need to move them to physical DHCP server . The users interfaces are on the ASA so we need to use the DHCP relay feature on the ASA but when i am trying to add it it is giving me the following :
DHCPRA: can't enable DHCP Relay when DHCPD is running on any interface
       Use the 'no dhcpd enable <server_ifc>' command
       on any interface that has been enabled.
dhcprelay command failed
even though i have deleted the dhcpd server commands for WIRELESS-EMPLOYEE & WIRELESS-GUEST-USER but still it is not working . My question is will the relay feature work when we want to move only interface gig0/1.504 & gig0/1.505 to relay and keep 0/1.599 for dhcpd server . Do i need to remove all the subinterfaces from dhcpd sever inorder relay to work on this interface ?
My configurations are :
interface GigabitEthernet0/1.504
description REQUIRES AD AUTHENTICATION
vlan 504
nameif WIRELESS-EMPLOYEE
security-level 50
ip address 192.168.xx.xx 255.255.252.0 standby 192.168.xx.xx
interface GigabitEthernet0/1.505
description REQUIRES NAC GUEST ACCOUNT
vlan 505
nameif WIRELESS-GUEST-USER
security-level 50
interface GigabitEthernet0/1.599
description GUEST_RH1
vlan 599
nameif GUEST_RH1
security-level 50
ip address 192.168.xx.xx 255.255.255.224 standby 192.168.xx.xx
dhcpd lease 1800
dhcpd address 192.168.xx.xx-192.168.xx.xx WIRELESS-EMPLOYEE
dhcpd enable WIRELESS-EMPLOYEE
dhcpd address 192.168.xx.xx-192.168.xx.xx WIRELESS-GUEST-USER
dhcpd enable WIRELESS-GUEST-USER
dhcpd address 192.168.xx.xx-192.168.xx.xx GUEST_RH1
dhcpd enable GUEST_RH1
Jouni Forss Sun, 12/01/2013 - 23:17
To my understanding if you are configuring DHCP Relay on the ASA you cant have a DHCP Server running on the ASA for the interfaces that are somehow participating in the DHCP Relay.
This means that you cant have the ASA acting as DHCP Server for clients on the interface that contains the clients for the DHCP Relay or on the interface where the DHCP Server for DHCP Relay is configured. If your actual DHCP Server is located behind the subint Gi0/1.599 then you can run DHCP Server for clients on that server.
- Jouni
Marius Gunnerud Mon, 12/02/2013 - 01:03
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
You say that you have removed the DHCD config from the interfaces, but in the output you posted the configuration is still there?
Issue the following commands and then test please.
no dhcpd enable WIRELESS-EMPLOYEE
no dhcpd enable WIRELESS-GUEST-USER
dhcprelay server
dhcprelay enable WIRELESS-EMPLOYEE
dhcprelay enable WIRELESS-GUEST-USER
dhcprelay setroute WIRELESS-EMPLOYEE
dhcprelay setroute WIRELESS-GUEST-USER
Please remember to rate and select a correct answer
