Warning message
vmiller Mon, 12/02/2013 - 07:49
  • Gold, 750 points or more
i have always understood the frame to be the Layer 2 only construct.
Once you get L3 involved (even in you case listed above) its a packet.
No hard science just years of how its been done.
Sandeep Choudhary Mon, 12/02/2013 - 08:02
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
adding to vmiller..
The Network Access Layer is Ethernet, ATM, Frame Relay and so on. Anything that fits in this layer is a FRAME. Frame is a lower-level idea. Frames are used on cabling systems. The cabling system can have multiple stations connected on the cable. A frame has framing to mark the beginning and end, sender and receiver addresses to indicate the stations on the cable, low-level control information, and a payload.
The Internet Layer is where IP was defined. Anything in this layer IS A PACKET.A packet is a block of user data, such as a piece of an e-mail message, with a network address pasted onto the front. Packets are used on networks. The network equipment looks at the network address and uses this information to make a route decision.
see the comparision: http://www.wifinotes.com/computer-networks/frame-vs-packets.html
Dont forget to rate helpful posts.
milan.kulik Mon, 12/02/2013 - 08:19
  • Red, 2250 points or more
run Wireshark in your LAN for a while.
You will see TCP segments inside IP packets inside Ethernet frames probably.
This will illustrate different network layers for you.
Best regards,
Milan
Richard Burts Mon, 12/02/2013 - 09:43
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Milan
I like your response very much. It is short, direct, to the point, and correct +5
Rick
