BE3000 and BRI Question
btl
Does anyone have a "tried and tested" solution for connecting BRI ISDN to the Cisco BE3000? I understand it can be done with an integrated services router, would anyone be able to advise which?
Ben,
Its matter of having any router (28XX/29XX)preferly with a T1/E1 wic card.
After that you need to add the router to CUCM using either MGCP/SIP/H323 and setting RP to outside...
COnfiguration can change between protocols...
Please Kudos/rate if this help!
