Warning message
chandra_rc16 Tue, 12/03/2013 - 03:58
Great. I think i cannot do DHCP labs in PT.
Router1(config)#service ?
  nagle                Enable Nagle's congestion control algorithm
  password-encryption  Encrypt system passwords
  timestamps           Timestamp debug/log messages
Question:
Will i see any questions regarding DHCP in CCNA exam ?
Chandu
cadet alain Tue, 12/03/2013 - 04:28
  • Purple, 4500 points or more
if it's part of the blueprint then you may have some questions about it and you can do DHCP in PT without any problem.
Alain
chandra_rc16 Tue, 12/03/2013 - 04:33
Alain,
I'm not seeing any options for that.
Chandu
cadet alain Tue, 12/03/2013 - 05:06
the service is enabled but can't be disabled.
Just configure your DHCP pools and connect a DHCP client and it will work.
Alain
dodi_forever_2003 Tue, 12/03/2013 - 05:28
Hi Chandra,
You can configure DHCP in PT with many different ways.
First, you can turn on the DHCP service on a Server, then add pools.
Second, you can enable DHCP on a multilayer switch using the following commands:
ip dhcp pool "pool name"
network "ip-network" "subnet mask"
default-router "ip-address"
lease (Infinite or days hours minutes)
Third, you can enable DHCP on a router using the same commands as mentioned in the second way.
Khaled Omar
Related Content
