Warning message
mp-bgp config
Dec 3rd, 2013
when I am enabling MP-BGP , I was reading couple of documents they say if you give command below .
address-family vpnv4
neighbor x.x.x.x activate
automattically for all VRF on that Layer 3 device "address-family ipv4 vrf vrf name " command is added in show running configration . like below
address-family ipv4 vrf VRF_1
address-family ipv4 vrf VRF_2
I was worred becuase I didnts wated all VRF to be communicating over MP-BGP
Thanks for help
John Blakley Tue, 12/03/2013 - 05:16
  • Purple, 4500 points or more
The vrf's are logical separations. When you enable a vrf in bgp, the vrf still has route-targets that either import or export other route-targets to share information between vrfs. When you have multiple vrfs configured under bgp like this, they don't automatically share information because they're configured under the vrf. That depends on how you have your vrf configured.
Enabling vpnv4 address family doesn't automatically configure bgp with the vrf address-family configuration (unless I'm misunderstanding what you're stating). You will have to have the vrf configured under bgp in order to share your routing information to your other PEs. This is also the place where you configure redistribution of other protocols.
HTH,
John
*** Please rate all useful posts ***
