Warning message
ASA 5505 help! wont boot
Dec 3rd, 2013
Any help will be great this is all I get from the console. Any suggestions will be great. Everything was woking perfectly!
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)13) #0: Thu Aug 28 15:55:27 PDT 2008
johnlloyd_13 Wed, 12/04/2013 - 00:30
  • Blue, 1500 points or more
hi lee,
looks like the IOS got deleted or corrupted.
you'll need to upload the IOS via ROMMON/TFTPDNLD by pressing the escape key.
rommon #1> address 192.168.1.1
rommon #2> server 192.168.1.2    <<< YOUR PC WITH TFTP
rommon #3> file
rommon #4> tftpdnld
leetobin1982 Wed, 12/04/2013 - 02:44
Thanks for taking time to look at this, I dont think i can reach rommon. I get "invalid Key" pressing ESC.
It wint boot any further than shown on the console output. I dont know if it helps but im using putty.
High Memory: 507 MB
PCI Device Table.
Invalid Key: 001B
Invalid Key: 001B
Invalid Key: 001B
narawat Wed, 12/04/2013 - 03:36
Hi Lee,
     what happens to the status light ?
I think you would need to replace the device, still would like to clarify the status light situation when the firewall boots.
Cheers,
Naveen
johnlloyd_13 Wed, 12/04/2013 - 04:40
Could you try using 'Break' key instead?
leetobin1982 Wed, 12/04/2013 - 13:57
Hi, thanks for the help tried that and nothing. Same key error.
leetobin1982 Wed, 12/04/2013 - 16:39
Ive left it a few hours and ive got this.
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
i2c_read_word_w_wait() error, slot = 0x0, device = 0x64, address = 134 byte count = 2. Reason: I2C_HOST_BUSY_ERROR
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Related Content
