Import maps error Prime 2.0
Dec 4th, 2013
I'm working to export maps from the old WCS 7.0.240.0 to Cisco Prime 2.0.
Everything works fine, but from one map I receive an error.
I cannot find what to do. Cisco has no workaround for it.
Map Path                Message        Status
WKL                      Length '328,080.719' is invalid. Range is '1' -'99,999'.       red dot
WKL                       Width '286,797.25'is invalid. Range is '1' -'99,999'.           red dot
My map named WKL has the maximum of 99999 meters. It looks like the WCS has counted the feet instead of meters.
I also change it in Prime 2.0, after I imported many other maps without any problem.
This looks very strange to me.
Does anyone have an answer to it.
Erik
Erik Boss Wed, 12/04/2013 - 06:54
I solved the problem to convert the old meter to feet.
Replacing the shops in the campus, saved it.
The export -> import and it works.
I seems to be a bug, but this will be the workaround.
Erik
Trending Topics - Security & Network
