Warning message
WAN VLAN ACL
Dec 4th, 2013
My apologies in advance if this has already been answered.
I have to limit a particular site from reaching other sites via our WAN cloud.  I believe the easiest is to "white list" the nets that are allowed and allow the implicit deny all take care of the rest.  So my question is this:
stack of 3750G (3) with a WAN VLAN configured
RTR----------OPTIMIZER----------3750G
If I apply the following ACL to the VLAN interface (VLAN 10) I should only allow access to the listed networks from the other networks behind the 3750, correct?
ip access-list extended COMP1_TO_COMP2
permit ip host 192.168.67.22 host 192.168.67.10  - WAN Router and BGP Peer
permit ip any host 192.168.67.20 --- Optimizer
permit ip any 10.1.0.0 0.0.255.255 --- net_1
permit ip any 10.10.0.0 0.0.255.255  --- net_2
permit ip any 10.40.0.0 0.0.255.255 --- net_3
ip access-list extended COMP2_TO_COMP1
permit ip host 192.168.67.10 host 192.168.67.22   - WAN Router and BGP Peer
permit ip host 192.168.67.20 --- Optimizer
permit ip 10.1.0.0 0.0.255.255 any -- Net_1
permit ip 10.10.0.0 0.0.255.255 any -- Net_2
permit ip 10.40.0.0 0.0.255.255 any -- Net_3
Interface VLAN10
ip address 192.168.67.22 255.255.255.0
ip access-list COMP1_TO_COMP2 OUT
ip access-list COMP2_TO_COMP1 IN
is this correct or am I completley wacked out???
Overall Rating: 4 (1 ratings)
Jon Marshall Wed, 12/04/2013 - 11:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
Not entirely sure what you are trying to do but you seem to have your acls the wrong way round. Vlan 10 uses the subnet 192.168.67.0/24  so -
1) the first line in each acl is redundant because the two IPs are in the same vlan so they won't go the vlan 10 interface
2) the acls are applied the wrong way. Inbound means traffic coming from clients on the vlan ie. 192.168.67.x clients and outbound is traffic going to the 192.168.67.x clients.
Jon
Chris McDaniel Wed, 12/04/2013 - 11:36
Hi Jon - Thanks for the quick reply...
What I am trying to accomplish is to restrict all users at this to only be able to access certain subnets at other sites.  And restrict certain sites from accessing this site.  Its a legal thing...  So the rest of this config would look like:
Vlan 10
ip addr 192.168.67.22
vlan 2
ip addr 10.70.0.1/23
vlan 30
ip addr 10.70.30.1/23
There are no users in the VLAN10 on the WAN router, Optimizer, and the Core.  So based on your response I should apply the COMP2_TO_COMP1 ACL on the user subnets as an INBOUND and COMP1_to_COMP2 as an OUTBOUND on VLAN 10...
yes?
Jon Marshall Wed, 12/04/2013 - 11:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
COMP2_to_COMP1 as an OUTBOUND on VLAN 10...
Do you want 10.1.0.0/16, 10.10.0.0/16 and 10.40.0.0/16 to access the devices in vlan 10 ? If so yes.
Could you perhaps be a bit more specific in what you actually want ?
Sorry it's been a long day so it could just be me
Jon
Chris McDaniel Wed, 12/04/2013 - 11:59
Hi Jon - no worries on the long day...
What I need to accomplish is:
10.70.0.0 users and devices should be blocked from accessing certain (100+) other subnets, while being able to access the contractual subnets and resources.  10.1.0.0 10.10.0.0 10.40.0.0 are some of the allowed subnets.  I assumed the ACL lines would be written like this:
ACL 1
permit ip 10.1.0.0 0.0.255.255 any -- this would be inbound from the WAN to the 10.70.0.0 subnets
ACL2
permit ip any 10.1.0.0 0.0.255.255 -- this would be from the site/user to the rest of the world
I'm thinking that ACL 1 should be applied IN on VLAN 10 and ACL 2 be applied IN on the user VLANs.....
Hope this clarifies...and thank you very much for your help!
Jon Marshall Wed, 12/04/2013 - 12:10
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
Okay i think i understand.
ACL1, if the traffic from the WAN has to go via the vlan 10 interface to get to the user vlans then yes apply it inbound on vlan 10.
ACL2 should indeed be applied inbound to the user vlans.
Jon
Julio Carvajal Wed, 12/04/2013 - 12:16
  • Purple, 4500 points or more
Hello Chris,
So the source of the traffic sits behind that VLAN right?
I certanly prefer to deny the inbound interface on the WAN interface but if you want to do it at the VLAN level then yes you should be good with that! Just remember to allow all the required traffic as this is not a stateful filtering check.
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Related Content
