3750 etherswitch module with no IOS
Dec 4th, 2013
I have a 3845 router with two 3750 etherswitch modules installed.   One of the switch modules has no IOS so it's stuck at the switch: prompt.   Anyone know where I can find any documentation on the commands that are available to me?   For instance,
switch: help boot
Usage for "boot" is:
    boot [-n|-j] [-p] [-c] [-f] [-i] [-m] [-notnd] [-notni] [-post] [-skip_post] [-reserve_mem <1-15>] [-no_esp_keepalive] [<filename>]
Also, can I boot this or download an image from a tftp server?   I've used the set command to set the IP, gateway, tftp server etc... but then what?  There's no tftpdnld command.
Thanks in advance....
cobra188d Thu, 12/05/2013 - 06:10
Thanks.   I've read that but it didn't answer my question about documentation on the commands that are available at the switch:  prompt.  Also, the 3750 Etherswitch has no console port.  How would I xmodem the IOS to the switch using the router console port?
