new 5508 controller installation and setup
Dec 4th, 2013
Hello all,
I hope I am posting this in the right area.
I have a new 5508 controller that I am working to get up and running. I will be connecting 2602 APs and am thinking that I have either missed a concept or missed a step in the configuration. I have the controller up and running on teh network. It is connected to the core switch using port 1 as a trunk port. I also created a seperate VLAN for the APs with DHCP but have been unable to get it to connect to the 5508 controller. I dod not configure anything on the controller before powering it up. I reading through the gonfiguration guide there is a reference to not having to create an AP management interface but also a recommendation to create AP management on each of the 8 interfaces on the controller. I have an AP management interface configured on teh controller and it has an IP address from the VLAN created for the APs.
What did / am I missing?
Thanks in advance.
Brent
bberry Wed, 12/04/2013 - 14:26
ok a little more on my issue. I think I have missed something somewhere as I have the following in the log.
*spamApTask0: Dec 04 16:23:37.433: #LWAPP-3-DISC_INTF_ERR2: spam_lrad.c:1558 Ignoring discovery request received on a wrong VLAN (32) on interface (1) in L3 LWAPP mode from AP 6c:41:6a:78:b1:56
The AP is in the 32 VLAN.
Brent
Daniel Ordonez Wed, 12/04/2013 - 14:34
  • Gold, 750 points or more
  • Participante Destacado,
    El Favorito: Noviembre 2015
You WLC and your AP's should be on the same VLAN
Leo Laohoo Wed, 12/04/2013 - 15:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Post the output to the following commands:
1.  WLC:  sh sysinfo; and
2.  AP:  sh version
Rasika Nayanajith Wed, 12/04/2013 - 19:45
  • Purple, 4500 points or more
    2017 Wireless
Hi Brent,
In 5508, you do not require AP-Manager interface to be configured. Management interface will act as AP-Manager interface for AP to join.
What is your WLC managment vlan ? Lets say if it is 100 (192.168.100.100/24 with gateway 192.168.100.1) then you should have configured it like this (via WLC console ). So your WLC & switch port (WLC & AP connected) should be like this. Pls check
(WLC) >config interface address management 192.168.100.100 255.255.255.0 192.168.100.1
(WLC) >config interface vlan management 100
SW#
int Gig x/x
desc WLC Trunk
sw trunk encapsulation dot1q
sw mode trunk
spanning-tree portfast trunk
int Gig x/y
desc AP
sw mode access
sw acc vlan 32
If your configuration is like above, you should be able to ping WLC mgmt from the AP itself. Try to test the registration you can statically configure the WLC mgt IP on the LAP by using the below command on AP CLI.
LAP#capwap ap controller ip address 192.168.100.100
Refer this post for more on AP registration & other method of controller discovery/etc. These posts are based on WLC7.0.116.0 code & you may see little bit different GUI if you using later codes.
1. http://mrncciew.com/2013/03/17/ap-registration/
2. http://mrncciew.com/2013/05/04/wlc-discovery-via-broadcast/
3. http://mrncciew.com/2013/02/27/configuring-dynamic-interfaces-on-wlc/
4. http://mrncciew.com/2013/01/25/backup-restore-wlc-configs/
Let us know if you still have AP regisration or 5508 config issues
Rasika
*** Pls rate all useful responses ****
bberry Thu, 12/05/2013 - 07:50
Thanks Rasika I will go back and double check what I have configured. I do not have any issues connecting to the WLC either with the CLI or the GUI. One other item. Will the AP management matter if I will eventually be controlling APs over the WAN?
I think I missed some fine print on the WLC configuration. I connected to an AP and received the following. It looks like I might need to tweak the DHCP configuration on my core switch for the AP VLAN and create a specific DNS entry for the WLC so that the AP can find it?
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 6 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 7040512
flashfs[0]: Bytes available: 24957440
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: bc:16:65:c1:ff:a8
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
flashfs[0]: flashfs fsck took 7 seconds.
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...#####################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x2003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (AP3G2-RCVK9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 00:07 by prod_rel_team
Initializing flashfs...
flashfs[2]: 6 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31739904
flashfs[2]: Bytes used: 7040512
flashfs[2]: Bytes available: 24699392
flashfs[2]: flashfs fsck took 9 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
memory validate-checksum 30
% Invalid input detected at '^' marker.
no ip http server
login authentication default
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Warning:  the compile-time code checksum does not appear to be present.
cisco AIR-CAP2602I-A-K9    (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FTX1718J251
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.4.1.37
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:C1:FF:A8
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1716309A
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FTX1718J251
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2602I-A-K9
% Please define a domain-name first.
logging facility kern
logging trap emergencies
Press RETURN to get started!
*Mar  1 00:00:10.415: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:12.079: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.903: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.943: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:12.943: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:13.931: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:15.471: DPAA Initialization Complete
*Mar  1 00:00:15.471: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:16.063: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:38.735: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inline power source
*Mar  1 00:00:48.663: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.168, mask 255.255.255.224, hostname APbc16.65c1.ffa8
Translating "CISCO-CAPWAP-CONTROLLER.spd.mli.corp"...domain server (172.16.4.243)
*Mar  1 00:00:59.547: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:59.547: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.spd.mli.corp
*Mar  1 00:01:38.747: %CDP_PD-4-POWER_OK: All radios disabled - NEGOTIATED inline power source
Not in Bound state.
*Mar  1 00:01:54.547: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:01:59.555: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:01:59.667: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.171, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 00:02:05.547: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:05.547: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.spd.mli.corp
Not in Bound state.
*Mar  1 00:02:51.047: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:02:56.055: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:56.167: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.173, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 00:03:02.047: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:02.047: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.spd.mli.corp
Rasika Nayanajith Thu, 12/05/2013 - 11:29
    2017 Wireless
Hi Brent,
No, you can have AP on different layer 3 network. Only requirement is AP should have L3 reachability to your WLC mgt IP.
Did you try "capwap ap controller ip address " command on your AP & see if it register. In this way you can quickly test your WLC config is ok.
Yes, to discover WLC you can either configure DHCP option 43 or Register  your WLC mgt IP for the  DNS entry of "CISCO-CAPWAP-CONTROLLER.spd.mli.corp".
Also make sure your WLC is sync with a NTP & correct country code to match the regulatory domain of your APs configured on it.
Rasika
**** Pls rate all useful responses ****
bberry Thu, 12/05/2013 - 13:23
Rasika,
Something odd .. I cannot get a response from the AP. I have the console connected and am getting things on the screen but if I hit enter or anything i get no response back. Kinda like it is locked until it goes active.
*Mar  1 05:40:05.622: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.7.162 obtained through DHCP
*Mar  1 05:40:05.622: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
*Mar  1 05:40:51.122: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 05:40:56.130: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 05:40:56.242: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.166, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 05:41:02.122: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.7.162 obtained through DHCP
*Mar  1 05:41:02.122: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
I can ping the AP address from the controller and am seeing a message in the log that says layer 3 discovery request not received on management VLAN. I have tried both the management IP address and the ap-management IP address with no change in the messages.
Leo Laohoo Thu, 12/05/2013 - 13:29
  • Hall of Fame,
    2017 LAN, Wireless
No, something is defintely wrong.  Time and date of the AP logs are very incorrect.  Can you please post the following command outputs:
2.  WLC:  sh time
bberry Thu, 12/05/2013 - 13:38
Leo,
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... Mem_5508
System Location.................................. Southwind Computer Room
System Contact................................... Mueller IS Dept.
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.5.110
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 0 mins 43 secs
System Timezone Location......................... (GMT -6:00) Central Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
External Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 7C:AD:74:8D:5B:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 12
(Cisco Controller) >show time
Time............................................. Thu Dec  5 15:34:57 2013
Timezone delta................................... 0:0
Timezone location................................ (GMT -6:00) Central Time (US and Canada)
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
       1              0          172.16.5.1       AUTH DISABLED
(Cisco Controller) >?
Leo Laohoo Thu, 12/05/2013 - 13:44
  • Hall of Fame,
    2017 LAN, Wireless
Can you ping the IP address of the management IP address of the WLC?
How is the link between the AP and the WLC like?  For the sake of this issue, can you ensure both the AP and the WLC are in the same VLAN and subnet?   It doesn't matter if the AP can't get a valid IP address, this can be addressed manually.
bberry Thu, 12/05/2013 - 13:53
Leo,
I have not tried to ping the all interfaces on the controller from the controller itself. The controller is connected to a trunk port on my sore switch and the AP is connected to a distribution switch off that same controller.
I have an AP-management interface in the same VLAN (VLAN32) as the AP and the controler management interface is in my network hardware VLAN (VLAN5). You are saying to see what happens when I move an AP into VLAN 5?
Leo Laohoo Thu, 12/05/2013 - 14:29
  • Hall of Fame,
    2017 LAN, Wireless
Nope.  I am suspecting you've got a routing issue somewhere in your network, hence I'm recommending you put the AP and the Management IP Address of the WLC into the same VLAN.
If you get the AP to join the WLC with this method, it only helps to prove that you've got a routing issue or a firewall issue.
Rasika Nayanajith Thu, 12/05/2013 - 14:56
    2017 Wireless
Hi Brent,
Looks like you have configured DHCP Option 43, but controller IP address AP getting is wrong. As per your "show sysinfo" output 5508 mgmt is 172.16.5.110. So your DHCP option 43 to be configured to give this address as WLC IP. Pls correct that & see.
I have noticed this couple of times when I used USB-Serial cable to console in. When I change the USB port in my laptop end most of time it get fixed.
You should get  console output no matter what (it is not requireed to active or registered to get this AP console output
Rasika
bberry Fri, 12/06/2013 - 06:21
Rasika,
It looks like changing the Option 43 to use the controller IP address did the trick. I still do not see a reason then for the AP-management interface? It looks like I still have a few more items to tweak to getting everything setup.
*Mar  1 22:26:34.822: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.7.162 obtained through DHCP
*Mar  1 22:26:34.822: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
*Mar  1 22:27:20.322: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 22:27:25.326: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 22:27:25.442: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.179, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 22:27:31.322: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.7.162 obtained through DHCP
*Mar  1 22:27:31.322: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
*Mar  1 22:28:16.822: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 22:28:21.826: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 22:28:21.950: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.181, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 22:28:27.822: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.5.110 obtained through DHCP
*Mar  1 22:28:27.822: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 22:28:37.822: %CAPWAP-3-ERRORLOG: Go join a capwap controller
examining image...
extracting info (287 bytes)
Image info:
    Version Suffix: k9w8-.152-2.JB2
    Image Name: ap3g2-k9w8-mx.152-2.JB2
    Version Directory: ap3g2-k9w8-mx.152-2.JB2
    Ios Image Size: 1331712
    Total Image Size: 11448832
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: AP3G2
    Wireless Switch Management Version: 7.4.110.0
Extracting files...
ap3g2-k9w8-mx.152-2.JB2/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/V2.bin (12826 bytes)
extracting ap3g2-k9
*Dec  6 14:09:20.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:09:20.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:09:20.467: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.5.110
*Dec  6 14:09:20.467:w8-mx.152-2.JB2/Y2.bin (5830 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/8004.img (1120540 bytes) %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  6 14:09:20.467: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  6 14:09:20.467: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  6 14:09:20.467: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 172.16.5.110perform archive download capwap:/ap3g2 tar file
*Dec  6 14:09:20.471: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
extracting ap3g2-k9w8-mx.152-2.JB2/X5.bin (61798 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-mx.152-2.JB2 (205508 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/B2.bin (9328 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/info (287 bytes)
ap3g2-k9w8-mx.152-2.JB2/html/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-2.JB2/html/level/ (directory) 0 (bytes)
ap3g2-k9w8-mx.152-2.JB2/html/level/1/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/forms.js (17492 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/appsui.js (563 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/ap_home.shtml.gz (1297 bytes)
ap3g2-k9w8-mx.152-2.JB2/html/level/1/images/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/images/info.gif (399 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/images/cisco-logo-2007.gif (1648 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/images/background_web41.jpg (732 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/images/login_homeap.gif (19671 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/config.js (25507 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/sitewide.js (16554 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/officeExtendap.css (41801 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/1/back.shtml (512 bytes)
ap3g2-k9w8-mx.152-2.JB2/html/level/15/ (directory) 0 (bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapBanner.htm (7114 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapConfig.shtml.gz (2864 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapSummary.htm (718 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapHelp.htm (5013 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapMain.shtml.gz (3350 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/html/level/15/officeExtendapEvent.shtml.gz (988 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/B5.bin (106106 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/E5.bin (92114 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/Y5.bin (75790 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-xx.152-2.JB2 (9531127 bytes)
*Dec  6 14:11:20.471: %CAPWAP-3-ERRORLOG: Invalid event 48 & state 10 combination.
*Dec  6 14:11:20.471: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message. Event 48, state 10
*Dec  6 14:11:20.471: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Dec  6 14:11:20.471: %CAPWAP-3-ERRORLOG: Failed to process timer message.
extracting ap3g2-k9w8-mx.152-2.JB2/X2.bin (15158 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/E2.bin (
Writing out the event log to flash:/event.log ...
18656 bytes)
extracting ap3g2-k9w8-mx.152-2.JB2/V5.bin (11660 bytes)
extracting info.ver (287 bytes)
New software image installed in flash:/ap3g2-k9w8-mx.152-2.JB2
Configuring system to use new image...done.
archive download: takes 158 seconds
*Dec  6 14:11:58.835: image upgrade successfully, system is now reloading
*Dec  6 14:11:58.875: %SYS-5-RELOAD: Reload requested by capwap image download proc. Reload Reason: NEW IMAGE DOWNLOAD.
*Dec  6 14:11:58.875: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
flash is writable
flashfs[0]: 38 files, 8 directories
flashfs[0]: Bytes used: 18556416
flashfs[0]: Bytes available: 13441536
flashfs[0]: flashfs fsck took 17 seconds.
Loading "flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-mx.152-2.JB2"...###########################
File "flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-mx.152-2.JB2" uncompressed and installed, entry point: 0x2003000
executing...
flashfs[0]: flashfs fsck took 8 seconds.
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-xx.152-2.JB2;flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-mx.152-2.JB2'
Loading "flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-xx.152-2.JB2"...#############################
File "flash:/ap3g2-k9w8-mx.152-2.JB2/ap3g2-k9w8-xx.152-2.JB2" uncompressed and installed, entry point: 0x2003000
executing...
           cisco Systems, Inc.
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 11:27 by prod_rel_team
flashfs[3]: 38 files, 8 directories
flashfs[3]: Total bytes: 31739904
flashfs[3]: Bytes used: 18556416
flashfs[3]: Bytes available: 13183488
flashfs[3]: flashfs fsck took 9 seconds.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Radio0  present 8764 8000 0 A8000000 A8010000 0
Rate table has 244 entries (64 SGI/104 BF variants)
Radio1  present 8764 8000 0 88000000 88010000 4
[email protected].
LWAPP image version 7.4.110.0
2 802.11 Radios
*Mar  1 00:00:10.323: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:10.323: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:13.831: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.503: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:23.875: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:23.923: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:26.403: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:26.403: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:26.467: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:26.467: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Mar  1 00:00:26.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:26.479: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:26.619: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:27.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:27.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:27.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:27.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:29.995: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:29.995: DPAA Initialization Complete
*Mar  1 00:00:29.995: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:30.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:55.331: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:59.019: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:01:00.115: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.207: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:02.107: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.183, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 00:01:02.207: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.spd.mli.corp"...domain server (172.16.4.243) [OK]
*Mar  1 00:01:12.991: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.5.110 obtained through DHCP
*Mar  1 00:01:12.991: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:22.991: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  6 14:14:21.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:14:21.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:14:21.467: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.5.110
*Dec  6 14:14:21.471: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  6 14:14:21.471: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  6 14:14:21.471: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  6 14:14:21.471: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 172.16.5.110
*Dec  6 14:14:21.887: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  6 14:14:21.951: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  6 14:14:22.019: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Mem_5508
*Dec  6 14:14:22.079: ac_first_hop_mac - IP:172.16.7.161 Hop IP:172.16.7.161 IDB:BVI1
*Dec  6 14:14:22.079: Setting AC first hop MAC: 0008.e3ff.fc28
*Dec  6 14:14:22.147: ac_first_hop_mac - IP:172.16.7.161 Hop IP:172.16.7.161 IDB:BVI1
*Dec  6 14:14:22.147: Setting AC first hop MAC: 0008.e3ff.fc28
*Dec  6 14:14:22.147: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Dec  6 14:14:22.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  6 14:14:22.923: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec  6 14:14:22.931: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec  6 14:14:23.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec  6 14:14:23.915: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec  6 14:14:23.947: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Dec  6 14:14:23.951: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec  6 14:14:23.959: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  6 14:14:23.967: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  6 14:14:24.951: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec  6 14:14:24.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  6 14:14:24.987: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  6 14:14:25.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec  6 14:14:34.463: %CLEANAIR-6-STATE: Slot 0 disabled
*Dec  6 14:14:34.463: %CLEANAIR-6-STATE: Slot 1 disabled
flash is writable
flashfs[0]: 39 files, 9 directories
flashfs[0]: Bytes used: 18562560
flashfs[0]: Bytes available: 13435392
executing...
executing...
           cisco Systems, Inc.
flashfs[3]: 39 files, 9 directories
flashfs[3]: Bytes used: 18562560
flashfs[3]: Bytes available: 13177344
[email protected].
2 802.11 Radios
*Mar  1 00:00:10.327: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:10.331: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:13.835: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:17.507: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:23.879: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:26.419: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:26.419: %SNMP-5-COLDSTART: SNMP agent on host APbc16.65c1.ffa8 is undergoing a cold start
*Mar  1 00:00:26.475: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:26.475: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:26.635: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:27.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:27.471: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:27.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:27.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:30.019: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:30.019: DPAA Initialization Complete
*Mar  1 00:00:30.019: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:30.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:55.339: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:58.875: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:59.967: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:00.323: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.7.183, mask 255.255.255.224, hostname APbc16.65c1.ffa8
*Mar  1 00:01:00.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.059: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:01.067: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:01:01.075: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:01:02.095: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:03.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:01:11.311: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.5.110 obtained through DHCP
*Mar  1 00:01:11.311: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:21.311: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  6 14:16:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:16:56.467: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.5.110 peer_port: 5246
*Dec  6 14:16:56.467: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.5.110
*Dec  6 14:16:56.467: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  6 14:16:56.467: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  6 14:16:56.467: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  6 14:16:56.467: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 172.16.5.110
*Dec  6 14:16:56.895: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  6 14:16:56.959: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  6 14:16:57.023: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Mem_5508
*Dec  6 14:16:57.083: ac_first_hop_mac - IP:172.16.7.161 Hop IP:172.16.7.161 IDB:BVI1
*Dec  6 14:16:57.083: Setting AC first hop MAC: 0008.e3ff.fc28
*Dec  6 14:16:57.087: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  6 14:16:57.155: ac_first_hop_mac - IP:172.16.7.161 Hop IP:172.16.7.161 IDB:BVI1
*Dec  6 14:16:57.155: Setting AC first hop MAC: 0008.e3ff.fc28
*Dec  6 14:16:57.155: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Dec  6 14:16:57.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  6 14:16:57.931: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec  6 14:16:57.939: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec  6 14:16:58.087: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec  6 14:16:58.923: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec  6 14:16:58.955: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Dec  6 14:16:58.959: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec  6 14:16:58.967: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  6 14:16:58.975: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  6 14:16:59.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec  6 14:16:59.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  6 14:16:59.995: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  6 14:17:00.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Rasika Nayanajith Fri, 12/06/2013 - 10:27
    2017 Wireless
Hi Brent,
Glad you got it working
As I stated earlier, for 5508 controller WLC management interface will act as AP-Manager interface & hence you do not want to configure AP-Manager interface.
Pls mark this thread as "answered" & rate all useful responses. That will help others
Rasika
