I just wanted to clean up * decommissioned and * physically removed blade servers by * selecting one and pressing ["Delete"] at the bottom as usual from the inventory. But UCSM fails: "Operation is not permitted" Any Idea how to overcome this?
The content you are looking for has been archived. View related content below.
Hi All, My hyperflex cluster failed with the error "configure Service profile(SP) failed" "Associating Service Profile" during the UCSM configuration in each server but validation was successful. I have 6 nos of hyperflex UCS 240 m5 all-flash nodes a...
Cisco Fabric Interconnect is having some Pmon Services as failed ================================================== FI-B(local-mgmt)# show pmon state SERVICE NAME STATE RETRY(MAX) EXITCODE SIGNAL CORE------------ ----- ---------- -------- ------ ----...
hi i am trying to cable up trhe ucs 6454. I got 2 40G mopdules on port 53 and 54 on each fabric. I got 2 core switches to connect therm to FABRIC 1port 53 ----> port 1 on Core switch APort 54 -----> port 1 on Core Switch BFABRIC 2port 53 ------> port...
Hello I am kwon. FI 6248 has been determined to be RMA and is scheduled for replacement. However, the existing FI is using UCS-FI-E16UP. If I install this with RMA FI, will the 8 port license of UCS-FI-E16UP be activated?
OLVM requires fence agent setup for power managementAll listing of Service Profiles in the Cisco 6296 environment with B200M3's were testing fine.Listing Service Profiles : fence_cisco_ucs --ip='10.16.16.80' --username='fence-kvm-user' --password='fe...
hi we are trying to upgrade at least to 4.1(3n) , I would like to know what would be the latest stable version that you recommend and what is the upgrade path for our current releases (4.0(1a) , 4.0(2b) and 4.1(3d)) ? for UCSC-C220-M5SX.
Hello,I would like to update our server usc m4 from GUI and not from ISO boot media. I found that i can do that by following:However, I cannot find the .bin for Bios or BMC in (ucs-c220m4-huu-4.1.2m.iso). How do i download them ?
I am repurposing a B200 M5.The server has 2nd Generation Intel Xeon Scalable ProcessorsI have 2 x 64GB and 2 x 32GB DIMMS.Referring to the Cisco UCS C220/C240/B200 M5 Memory Guide, I'm not sure what is the preferred method of populating memory.Should...
I have a B200 M5 blade that is physically stuck in the chassis.The release handle on the blade will not completely open and will not release the device.Any suggestion on how to remove it?
After upgrade to 2.1.2a, 2 UCS domains actually came with this error.Description: default Keyring's certificate is invalid, reason: unknownCause: invalid-keyring-certificateCode: F0909I did the procedureFI-A# scope securityFI-A/security # scope keyri...
Hello all,on one of my SNS-3755-K9 Applience can not open vkvm.after clicking on start and accepting "Load KVM Certifivate" i recieve a blank new Page and 3 Errors (see Screen Shots)Please take a look at this Problem as sonn as possible. Reset Facto...
Hello UCS frinds My Question is -Can I change the Chassis/FEX discovery Policy ONLINE from "none" to "port Channel" After I set it to Port Channel i have to reacknowledge the Chassis Can I Do this online? Without intetrrupt?
Hello,we are performing a staging and firmware updates on a bunch of C220 M5 standalone servers delivered with CIMC 4.1(2a) loaded. After initial CIMC setup we are able to connect to CIMC GUI, all looking fine, however, we are unable to launch vKVM c...
I am installing cisco virtual connected appliance using vcenter client hosted on esxi host. I followed the installation steps from cisco (https://www.cisco.com/c/en/us/td/docs/unified_computing/Intersight/b_Cisco_Intersight_Appliance_Getting_Started_...
Subject | Author | Posted |
04-23-2024 12:18 AM | ||
04-16-2024 02:26 AM | ||
04-04-2024 11:22 AM | ||
03-18-2024 06:52 AM | ||
02-27-2024 07:34 AM |
