Warning message
Best ASA and ASDM version combination
Answered Question
Dec 5th, 2013
We are using ASA version: 8.4(2) & ASDM version: 6.4(7) and its very stable combination.
Q1: Is there any new STABLE version of ASA & ASDM available and if yes then please advise the best combination of ASA & ASDM.
Q2: How we will compare the new suggested version of ASA feature and stability with our current combinations i.e. ASA version: 8.4(2) & ASDM version: 6.4(7).
Q3: Please only suggest a version, if its very stable, as we will then follow your suggestion and upgrade about 60 ASA.
Thanks.
Correct Answer by Julio Carvajal about 3 years 8 months ago
This is by far the link you are looking for
http://www.cisco.com/en/US/partner/docs/security/asa/compatibility/asamatrx.html
You will see everything you need from there bud
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Overall Rating: 5 (1 ratings)
Related Content
