Connect Hg2845 to cisco 3560-x switch to distribute internet
abidpandhakkil
Hello All,
First of all I am a novice when it comes to cisco switches and routers.
I will provide you the setup I have :
1) 1x Huawei HG2845 wireless modem/ router with Fiber connection coming from the Vendor. It is a shared connection
IP Address: 192.168.100.1
I can access the wireless connection on my devices to access the internet from this Huawei device.
2) 1x Cisco 3560-X PoE switch which is brand new [not configured] with connections to the end users
IP Address : 10.0.0.1 [default IP of cisco, I believe]
I connected the HG2845 to the Cisco via a straight through cable. I connected it to the 39th port of the switch [Gigabit Ethernet 0/39]. There is no specfic Up/Downlink ports with this switch.
What are the settings/commands I would require to do in order for
          a) the internet to be available to the devices connected via the switch ?
          b) Do I require any other devices for this to work?
Looking forward for techies reply.
5 Replies 5
abidpandhakkil
Support,
Looking forward for your suggestions and comments
1° on switch:
-on port connected to Huawei:
int g0/39
no switchport
ip address 192.168.100.x 255.255.255.0
-in global config:
ip routing
ip route 0.0.0.0 0.0.0.0 192.168.100.1
2° on Huawei:
-configure a route for the client subnet behind the switch pointing to the ip address of the switch(192.168.100.x)
All of this is assuming that the Huawei can NAT not directly connected networks otherwise you'll have to insert a router or firewall in between that will nat the switch subnet.
Of course you could change other stuff on the switch but they are not mandatory for your topology to work( change the vlan assignment,configure switch as vtp transparent,change the management vlan,...)
Alain
Dear Alain,
Thank you for your response.
As per your guidance:
On Int G0/39
Ip address 192.168.100.2 255.255.255.0
## It gives the message : %IP-4-DUPADDR: Duplicate address 192.168.100.1 on GigabitE
thernet0/39, sourced by 200b.c771.a491 #######
Anyhow, I have completed the rest of the commands as well on the Switch. However, I have concerns regarding setting up the Huawei route. Please find attached 2 pics from the huawei panel
PS: I have a Cisco 1941 as well if introducing that helps in the connectivity.
Looking forward for your reply.
Can you provide the running config of the switch and specify the IP config  of huawei.
How are your 2 devices connected ?
Alain
Running Config of switch can be found below: Pls note that I changed the Gi0/39 to switchport mode access from no switchport.
There are 4 LAN ports for the Huawei:
LAN3 is connected to Switch via RJ45 on Gi0/39
For Huawei IP
LAN IP : 192.168.100.1
DHCP : TURNED OFF
DNS : 192.168.100.1
WAN IP : ISP IP [NoT Dedicated]
Cisco 3560 Catalyst Config:
Version 12.2
no service pad
hostname switch2
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address dhcp
ip classless
ip http server
ip http secure-server
line con 0
line vty 5 15
end
Please let me know if you need any further info:
