Warning message
cisco aaa coa and l4 redirect not working on csr 1000v
Dec 5th, 2013
I try to configure a cisco CSR 1000V in VMvare having 4 interfaces to do DHCP session creation with AAA Radius CoA and L4 Redirec to a portal page using PBHK service.
This my full configuration used.
Here is my inspiration link and scenario :
http://www.cisco.com/en/US/docs/ios/12_2sb/isg/coa/guide/isgcoa4.html
My COA work good, I used for testing radclient and changes the subscriber session from unauth to authenticated.
My issue is that the redirect to captive portal is not working and I don't know why?
Do I have to add AAA user profiles for l4 service on Radius server? What config should be added on Radius server ?
Can you please help me with config?
Here are parts from my config also:
! Last configuration change at 22:48:29 UTC Fri Nov 29 2013
version 15.3
service internal
no platform punt-keepalive disable-kernel-core
platform console virtual
hostname CISCO-CSR1000v
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa group server radius RAD-SRV-GRP
server 192.168.100.123 auth-port 1812 acct-port 1813
ip radius source-interface Loopback1
aaa authentication login RAD-ALL group RAD-SRV-GRP
aaa authorization network RAD-ALL group RAD-SRV-GRP
aaa authorization subscriber-service default local group RAD-SRV-GRP
aaa accounting network RAD-ALL
action-type start-stop
group RAD-SRV-GRP
aaa server radius dynamic-author
client 192.168.100.123
server-key cisco
port 3799
auth-type all
ignore session-key
ignore server-key
aaa session-id common
no ip source-route
no ip domain lookup
ip address-pool local
ip dhcp excluded-address 192.168.200.1
ip dhcp pool WiFi_DHCP_POOL1
network 192.168.200.0 255.255.255.0
dns-server 192.168.1.1
default-router 192.168.200.1
lease 0 0 30
class DHCP-WiFi-CL
ip dhcp class DHCP-WiFi-CL
subscriber service coa-rfc-compliant
subscriber service session-accounting
subscriber authorization enable
username root privilege 15 password 0 rootpass
redundancy
mode none
redirect server-group CP-PORTAL
server ip 192.168.100.123 port 80
no ip tftp source-interface GigabitEthernet0
class-map type traffic match-any REDIRECT-MAP
match access-group input name REDIRECT-ACL-UP
class-map type traffic match-any OPENGARDEN-MAP
match access-group input name OPENGARDEN-ACL-UP
match access-group output name OPENGARDEN-ACL-DW
class-map type control match-all INIT-SESSION
match timer INIT-SESSION-TIMER
match authen-status unauthenticated
policy-map type service REDIRECT-SERV
class type traffic REDIRECT-MAP
  redirect to ip 192.168.100.123 port 80
class type traffic default input
  drop
policy-map type service OPENGARDEN-SERV
class type traffic OPENGARDEN-MAP
  police input 1000000
  police output 3000000
class type traffic default in-out
  drop
policy-map type service PBHK-SERV
ip portbundle
policy-map type control WIFI-POL-1
class type control INIT-SESSION event timed-policy-expiry
  10 service disconnect
class type control always event session-start
  10 service-policy type service name PBHK-SERV
  20 service-policy type service name REDIRECT-SERV
  30 service-policy type service name OPENGARDEN-SERV
  40 set-timer INIT-SESSION-TIMER 5
class type control always event account-logon
  10 authenticate aaa list RAD-ALL
class type control always event service-start
  10 service-policy type service unapply name PBHK-SERV
  20 service-policy type service unapply name REDIRECT-SERV
  30 service-policy type service unapply name OPENGARDEN-SERV
  40 service-policy type service identifier service-name
class type control always event account-logoff
  10 service disconnect delay 5
class type control always event service-stop
  10 service-policy type service unapply identifier service-name
  20 service-policy type service name PBHK-SERV
  30 service-policy type service name REDIRECT-SERV
  40 service-policy type service name OPENGARDEN-SERV
interface Loopback1
ip address 192.168.255.1 255.255.255.255
interface GigabitEthernet1
description "Internet_Interface"
ip address 192.168.1.28 255.255.255.0
negotiation auto
interface GigabitEthernet2
description "AP_Interface"
ip address 192.168.200.1 255.255.255.0
negotiation auto
service-policy type control WIFI-POL-1
ip subscriber routed
  initiator unclassified ip-address
  initiator dhcp
interface GigabitEthernet3
description "Radius-Portal_Interface"
ip address 192.168.100.131 255.255.255.0
negotiation auto
vrf forwarding Mgmt-intf
ip address 192.168.50.130 255.255.255.0
negotiation auto
virtual-service csr_mgmt
activate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip access-list extended OPENGARDEN-ACL-DW
permit ip host 192.168.100.123 any
permit udp any eq domain any
ip access-list extended OPENGARDEN-ACL-UP
permit udp any any eq domain
permit tcp any host 192.168.100.123
ip access-list extended REDIRECT-ACL-UP
deny   ip any host 192.168.100.123
permit tcp any any eq www
permit tcp any any eq 8080
permit tcp any any eq 443
ip portbundle
match access-list 101
source Loopback1
access-list 101 permit tcp any host 192.168.100.123
radius-server attribute 44 include-in-access-req default-vrf
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req
radius-server attribute 31 send nas-port-detail mac-only
radius-server attribute 31 remote-id
radius-server host 192.168.100.123 auth-port 1812 acct-port 1813 key cisco
radius-server retransmit 5
radius-server timeout 10
radius-server key cisco
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0
exec-timeout 30 0
transport input telnet
line vty 1
exec-timeout 30 0
length 0
line vty 2 4
exec-timeout 30 0
onep
end
dhruv.ranparia1 Wed, 12/09/2015 - 23:04
Did you used External Portal ? and how do you identifies the session and generate CoA  ? as i am got stuck at generation CoA from Portal with PBHK identifier
can you help get the session information to generate CoA.
