Cisco ACE URL re-write / append
Dec 5th, 2013
Hi everyone..
I have a situation where a customer is moving from a legacy F5 to Cisco ??
Anyway the web site uses only http  and the rservers only listen on 80  also.   but the customer wants to have the URL re-directed or re-written
so for example:
http://website.com
to
http://website.com/something/
The issue I have is that a re-direct would match a class map on IP then re-direct then then come back into the ACE towards the same IP..  thus it would continully hit the re-direct.
this is the version of code on the ACE we are trying to use:
ftware
  loader:    Version 12.2[121]
  system:    Version A2(3.6a) [build 3.0(0)A2(3.6a)]
  system image file: [LCP] disk0:c6ace-t1k9-mz.A2_3_6a.bin
  installed license: no feature license is installed
Fnu Kanwaljeet Singh Thu, 12/05/2013 - 13:17
  • Cisco Employee,
Hi Norm,
You can match on the basis of URL using class-map type http.
Kanwal
Fnu Kanwaljeet Singh Thu, 12/05/2013 - 13:48
  • Cisco Employee,
Hi Norm,
To elaborate a bit you can redirect users coming with website.com and anyone coming with /something should be loadbalanced. You will need to use the combination or L3/l4 class map and L7 class map matching URL.
Let me know if you have any questions or doubts.
Kanwal
normbeef Fri, 12/06/2013 - 01:59
Hi,   I think we have a misunderstanding..
Nobody comes into the load balancer with anything apart from
http://website.com
I need the load balancer to add    /something/    to the end of the URL and forward it onto the rserver below.  (on port 80)
so you hit the VIP class map on  IP /  port  80
Then the load balancer adds the /something/
then forwards you on to the Application server.
Fnu Kanwaljeet Singh Fri, 12/06/2013 - 08:11
  • Cisco Employee,
Hi Norm,
You can use action-list and try the below example. Let me know how it goes.
action-list type modify http TESTURL-ACTION
 header rewrite request Host header-value " www[.]a[.]com/test[.]html"
replace " www[.]a[.]com/test/test[.]html"
So the above example rewrites the request www.a.com/test.html to www.a.com/test/test.html
Kanwal
Related Content
