Where does the extra outside route come from?
Answered Question
Dec 6th, 2013
VPN-ASA5505# sh route inside
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is <IP address> to network 0.0.0.0
S    172.16.55.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    192.168.174.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.1.43.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.1.32.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.225.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.35.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.8.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.9.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.10.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.12.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.2.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.160.0.0 255.255.0.0 [1/0] via 10.161.0.1, inside
C    10.161.0.0 255.255.0.0 is directly connected, inside
S    10.162.7.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.30.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.19.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.20.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.21.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.110.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.99.0 255.255.255.0 [1/0] via 10.161.0.1, inside
S    10.162.95.0 255.255.255.0 [1/0] via 10.161.0.1, inside
VPN-ASA5505#
VPN-ASA5505#
VPN-ASA5505# sh route outside
S    10.92.1.1 255.255.255.255 [1/0] via <IP address>, outside
C    <IP address> 255.255.255.224 is directly connected, outside
S*   0.0.0.0 0.0.0.0 [1/0] via <IP address>, outside
VPN-ASA5505#
VPN-ASA5505#
VPN-ASA5505# sh run | incl route
route outside 0.0.0.0 0.0.0.0 <IP address> 1
route inside 10.1.32.0 255.255.255.0 10.161.0.1 1
route inside 10.1.43.0 255.255.255.0 10.161.0.1 1
route inside 10.160.0.0 255.255.0.0 10.161.0.1 1
route inside 10.162.2.0 255.255.255.0 10.161.0.1 1
route inside 10.162.7.0 255.255.255.0 10.161.0.1 1
route inside 10.162.8.0 255.255.255.0 10.161.0.1 1
route inside 10.162.9.0 255.255.255.0 10.161.0.1 1
route inside 10.162.10.0 255.255.255.0 10.161.0.1 1
route inside 10.162.12.0 255.255.255.0 10.161.0.1 1
route inside 10.162.19.0 255.255.255.0 10.161.0.1 1
route inside 10.162.20.0 255.255.255.0 10.161.0.1 1
route inside 10.162.21.0 255.255.255.0 10.161.0.1 1
route inside 10.162.30.0 255.255.255.0 10.161.0.1 1
route inside 10.162.35.0 255.255.255.0 10.161.0.1 1
route inside 10.162.95.0 255.255.255.0 10.161.0.1 1
route inside 10.162.99.0 255.255.255.0 10.161.0.1 1
route inside 10.162.110.0 255.255.255.0 10.161.0.1 1
route inside 10.162.225.0 255.255.255.0 10.161.0.1 1
route inside 172.16.55.0 255.255.255.0 10.161.0.1 1
route inside 192.168.174.0 255.255.255.0 10.161.0.1 1
VPN-ASA5505#
Correct Answer by Julio Carvajal about 3 years 8 months ago
From Reverse Route Injection VPN  I guess
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Overall Rating: 5 (1 ratings)
Sal Robertson Fri, 12/06/2013 - 08:18
But wouldn't that being configured show up in the configuration? I don't see reverse route injection anywhere... What does the command look like?
Julio Carvajal Fri, 12/06/2013 - 08:28
  • Purple, 4500 points or more
Show run | include reverse-route
10.92.1.1 belongs to which IP address pool? REmote IPsec users or Anyconnect?
Anyconnect by default has RR with no configuration needed
Jcarvaja
Sal Robertson Fri, 12/06/2013 - 08:29
VPN-ASA5505# sh run | incl reverse-route
VPN-ASA5505#
I am guessing it's Anyconnect. Not sure how to tell that,either.... #FirewallNovice....
Sal Robertson Fri, 12/06/2013 - 08:38
That would be yes. Thanks.
VPN-ASA5505# sh run | incl webvpn
webvpn
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
webvpn
webvpn
tunnel-group AnyConnect webvpn-attributes
