Warning message
CUCM 9.1.2 - Volume report for Translation Pattern
Dec 6th, 2013
Hello all,
I have a translation pattern going to a hunt pilot and need to find out the call volume of it.  If I just run a volume report on the hunt pilot, I only get results for when some directly calls the extension.  Is there a way to find the call volume that goes to the translation pattern?
Thank you.
James Hawkins Fri, 12/06/2013 - 13:40
  • Blue, 1500 points or more
I do not know any way to report on that specifically. I would just create a second hunt pilot and point your translation pattern at that (or delete the translation pattern and use the number directly for the hunt pilot).
Related Content
