[asr9k filesystem] change directory
Carlos A. Silva
Level 3
Level 3
Dear, CSC:
Maybe you could help me out with this. Customer put a USB on an asr9001, but put files on a directory called 'IOS ASR9001' (space between IOS and ASR9001). it's been a nightmare trying to work with this directory, since i can't even 'cd' to it:
RP/0/RSP0/CPU0:x#cd disk1:
RP/0/RSP0/CPU0:x#dir
Fri Dec  6 23:56:19.455 CST
Directory of disk1:
131072      ----  0           Fri Dec  6 09:52:22 2013  =KINGSTON
3           drwx  16384       Fri Dec  6 09:53:09 2013  IOS ASR9001
139277      drwx  16384       Fri Dec  6 13:37:36 2013  LOST.DIR
7794851840 bytes total (5512953856 bytes free)
RP/0/RSP0/CPU0:x#
RP/0/RSP0/CPU0:x#cd IOS*
cd failed: No such file or directory
RP/0/RSP0/CPU0:x#cd "IOS ASR9001"
RP/0/RSP0/CPU0:x#cd IOS\ ASR9001
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:x#
any chance you know a workaround? weird thing how i can list stuff on that directory, but not cd into it or copy stuff from it.
RP/0/RSP0/CPU0:x#dir disk1:"IOS ASR9001"
Sat Dec  7 00:03:01.510 CST
Directory of disk1:/IOS ASR9001
196768      -rw-  32762394    Thu Mar 22 06:36:07 2012  asr9k-p-4.1.2.CSCty67156.pie
196896      -rw-  2972        Thu Mar 22 08:30:31 2012  asr9k-p-4.1.2.CSCty67156.txt
197024      -rw-  27371726    Tue Mar 29 17:51:45 2011  asr9k-p-4.0.1.CSCto05713.pie
197152      -rw-  2712        Tue Mar 29 22:11:45 2011  asr9k-p-4.0.1.CSCto05713.txt
197280      -rw-  40910815    Thu Jan 10 04:52:21 2013  asr9k-p-4.2.3.CSCud54093.pie
thanks in advance
c.
smilstea
That is a known limitation and will be fixed via a FPD upgrade to rommon in 5.1.1
Sam
smilstea
Sam
Carlos A. Silva
Level 3
Level 3
Thank you very much, Sam. At least I can't stop obsessing how to make it work.
