A possible bug related to the Cisco ASA "show access-list"?
Answered Question
Dec 6th, 2013
We encountered a strange problem in our ASA configuration.
In the "show running-config":
access-list inside_access_in remark CM000067 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:http_access
access-list inside_access_in remark CM000458 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:https_access
access-list inside_access_in remark test 11111111111111111111111111 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security
access-list inside_access_in extended permit tcp host 1.1.1.1 host 192.168.20.86 eq 81 log
access-list inside_access_in remark CM000260 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-dgm
access-list inside_access_in remark CM006598 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-ns
access-list inside_access_in remark CM000220 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-ssn
access-list inside_access_in remark CM000223 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:tcp/445
access-list inside_access_in extended permit tcp 172.31.254.0 255.255.255.0 any eq www log
access-list inside_access_in extended permit tcp 172.31.254.0 255.255.255.0 any eq https log
access-list inside_access_in extended permit udp 172.31.254.0 255.255.255.0 any eq netbios-dgm log
access-list inside_access_in extended permit udp 172.31.254.0 255.255.255.0 any eq netbios-ns log
access-list inside_access_in extended permit tcp 172.31.254.0 255.255.255.0 any eq netbios-ssn log
access-list inside_access_in extended permit tcp 172.31.254.0 255.255.255.0 any eq 445 log
access-list inside_access_in remark CM000280 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:domain
access-list inside_access_in extended permit tcp object 172.31.254.2 any eq domain log
access-list inside_access_in extended permit udp object 172.31.254.2 any eq domain log
access-list inside_access_in remark CM000220 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:catch_all
access-list inside_access_in extended permit ip object 172.31.254.2 any log
access-list inside_access_in remark CM0000086 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:SSH_internal
access-list inside_access_in extended permit tcp 172.31.254.0 255.255.255.0 interface inside eq ssh log
access-list inside_access_in remark CM0000011 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:PortRange
access-list inside_access_in extended permit object TCPPortRange 172.31.254.0 255.255.255.0 host 192.168.20.91 log
access-list inside_access_in remark CM0000012 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:FTP
access-list inside_access_in extended permit tcp object inside_range range 1024 45000 host 192.168.20.91 eq ftp log
access-list inside_access_in remark CM0000088 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:PortRange
access-list inside_access_in extended permit ip 192.168.20.0 255.255.255.0 any log
access-list inside_access_in remark CM0000014 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:DropIP
access-list inside_access_in extended permit ip object windowsusageVM any log
access-list inside_access_in extended permit ip any object testCSM-object
access-list inside_access_in extended permit ip 172.31.254.0 255.255.255.0 any log
access-list inside_access_in remark CM0000065 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:IP
access-list inside_access_in extended permit ip host 172.31.254.2 any log
access-list inside_access_in remark CM0000658 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security
access-list inside_access_in extended permit tcp host 192.168.20.95 any eq www log
In the "show access-list":
access-list inside_access_in line 1 remark CM000067 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:http_access
access-list inside_access_in line 2 remark CM000458 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:https_access
access-list inside_access_in line 3 remark test 11111111111111111111111111 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security
access-list inside_access_in line 4 extended permit tcp host 1.1.1.1 host 192.168.20.86 eq 81 log informational interval 300 (hitcnt=0) 0x0a                                                           3bacc1
access-list inside_access_in line 5 remark CM000260 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-dgm
access-list inside_access_in line 6 remark CM006598 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-ns
access-list inside_access_in line 7 remark CM000220 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:netbios-ssn
access-list inside_access_in line 8 remark CM000223 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:tcp/445
access-list inside_access_in line 9 extended permit tcp 172.31.254.0 255.255.255.0 any eq www log informational interval 300 (hitcnt=0) 0x06                                                           85254a
access-list inside_access_in line 10 extended permit tcp 172.31.254.0 255.255.255.0 any eq https log informational interval 300 (hitcnt=0) 0                                                           x7e7ca5a7
access-list inside_access_in line 11 extended permit udp 172.31.254.0 255.255.255.0 any eq netbios-dgm log informational interval 300 (hitcn                                                           t=0) 0x02a111af
access-list inside_access_in line 12 extended permit udp 172.31.254.0 255.255.255.0 any eq netbios-ns log informational interval 300 (hitcnt                                                           =0) 0x19244261
access-list inside_access_in line 13 extended permit tcp 172.31.254.0 255.255.255.0 any eq netbios-ssn log informational interval 300 (hitcn                                                           t=0) 0x0dbff051
access-list inside_access_in line 14 extended permit tcp 172.31.254.0 255.255.255.0 any eq 445 log informational interval 300 (hitcnt=0) 0x7                                                           b798b0e
access-list inside_access_in line 15 remark CM000280 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:domain
access-list inside_access_in line 16 extended permit tcp object 172.31.254.2 any eq domain log informational interval 300 (hitcnt=0) 0x6c416                                                           81b
  access-list inside_access_in line 16 extended permit tcp host 172.31.254.2 any eq domain log informational interval 300 (hitcnt=0) 0x6c416                                                           81b
access-list inside_access_in line 17 extended permit udp object 172.31.254.2 any eq domain log informational interval 300 (hitcnt=0) 0xc53bf                                                           227
  access-list inside_access_in line 17 extended permit udp host 172.31.254.2 any eq domain log informational interval 300 (hitcnt=0) 0xc53bf                                                           227
access-list inside_access_in line 18 remark CM000220 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:catch_all
access-list inside_access_in line 19 extended permit ip object 172.31.254.2 any log informational interval 300 (hitcnt=0) 0xd063707c
  access-list inside_access_in line 19 extended permit ip host 172.31.254.2 any log informational interval 300 (hitcnt=0) 0xd063707c
access-list inside_access_in line 20 remark CM0000086 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:SSH_internal
access-list inside_access_in line 21 extended permit tcp 172.31.254.0 255.255.255.0 interface inside eq ssh log informational interval 300 (hitcnt=0) 0x4951b794
access-list inside_access_in line 22 remark CM0000011 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:PortRange
access-list inside_access_in line 23 extended permit object TCPPortRange 172.31.254.0 255.255.255.0 host 192.168.20.91 log informational interval 300 (hitcnt=0) 0x441e6d68
  access-list inside_access_in line 23 extended permit tcp 172.31.254.0 255.255.255.0 host 192.168.20.91 range ftp smtp log informational interval 300 (hitcnt=0) 0x441e6d68
access-list inside_access_in line 24 remark CM0000012 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:FTP
access-list inside_access_in line 25 extended permit tcp object inside_range range 1024 45000 host 192.168.20.91 eq ftp log informational interval 300 0xe848acd5
  access-list inside_access_in line 25 extended permit tcp range 12.89.235.2 12.89.235.5 range 1024 45000 host 192.168.20.91 eq ftp log informational interval 300 (hitcnt=0) 0xe848acd5
access-list inside_access_in line 26 extended permit ip 192.168.20.0 255.255.255.0 any log informational interval 300 (hitcnt=0) 0xb6c1be37
access-list inside_access_in line 27 remark CM0000014 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:DropIP
access-list inside_access_in line 28 extended permit ip object windowsusageVM any log informational interval 300 (hitcnt=0) 0x22170368
  access-list inside_access_in line 28 extended permit ip host 172.31.254.250 any log informational interval 300 (hitcnt=0) 0x22170368
access-list inside_access_in line 29 extended permit ip any object testCSM-object (hitcnt=0) 0xa3fcb334
  access-list inside_access_in line 29 extended permit ip any host 255.255.255.255 (hitcnt=0) 0xa3fcb334
access-list inside_access_in line 30 extended permit ip 172.31.254.0 255.255.255.0 any log informational interval 300 (hitcnt=0) 0xe361b6ed
access-list inside_access_in line 31 remark CM0000065 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security JST:IP
access-list inside_access_in line 32 extended permit ip host 172.31.254.2 any log informational interval 300 (hitcnt=0) 0xed7670e1
access-list inside_access_in line 33 remark CM0000658 EXP:1/16/2014 OWN:IT_Security BZU:Network_Security
access-list inside_access_in line 34 extended permit tcp host 192.168.20.95 any eq www log informational interval 300 (hitcnt=0) 0x8d07d70b
There is a comment in the running config: (line 26)
This comment is missing in "show access-list". So in the access list, for all the lines after this comment, the line number is no longer correct. This causes problem when we try to use line number to insert a new rule.
Has anybody seen this problem before? Is this a known problem? I am glad to provide more information if needed.
Thanks in advance.
show version:
Cisco Adaptive Security Appliance Software Version 8.4(4)1
Device Manager Version 7.1(3)
Compiled on Thu 14-Jun-12 11:20 by builders
System image file is "disk0:/asa844-1-k8.bin"
Config file at boot was "startup-config"
fmciscoasa up 1 hour 56 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.06
                             Number of accelerators: 1
Correct Answer by Karsten Iwen about 3 years 8 months ago
Could be related to the following bug:
CSCtq12090: ACL remark line is missing when range object is configured in ACL
Fixed in 8.4(6), so update to a newer version and observe it again.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Overall Rating: 5 (1 ratings)
Correct Answer
Karsten Iwen Fri, 12/06/2013 - 15:50
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
configwatch Mon, 12/09/2013 - 09:40
I verified this is the source of the problem. After I removed the rule that uses the address range object, I can see the comment after that rule in the access list. The line numbers are also correct now.
Thanks for your help!
Related Content
