Warning message
EIGRP commands not showing up in WAN router config??
Answered Question
Dec 6th, 2013
Hello
I have this instance configured
router eigrp 10
network 10.44.x.101 0.0.0.0
I have added no auto-summary and a couple redistribute commands but they do not show up in config.
What am I doing wrong?
Correct Answer by daniel.dib about 3 years 8 months ago
Did the entire EIGRP config go away or just those lines of config? Depending on your IOS version no auto-summary might be the default and then it wouldn't show up in the config. Your redistribute statements should be there though.
If the entire config went away it's possible that you didn't have EIGRP active on any interfaces but that should not be the case if you put a network statement. Can you post the config?
Daniel Dib
CCIE #37149
Overall Rating: 5 (1 ratings)
Correct Answer
daniel.dib Fri, 12/06/2013 - 22:36
  • Silver, 250 points or more
Daniel Dib
CCIE #37149
Steve Coady Sat, 12/07/2013 - 00:01
Daniel
Thank you for the reply.
The IOS has it as the default. We are good to go
