Warning message
NAT NVI help
Dec 8th, 2013
Hello Everyone,
     Looking at this configuration would it be correct to say that the 50.50.50.17 subnet (Subinterface 50) would not be translated due to that it does not have the "ip nat enable" command when it exits fa0/1 (eventhough ip nat enable is turned on for this interface)? Or because of the command on fa0/1 does the address have to translate?
interface FastEthernet0/0
no ip address
interface FastEthernet0/0.1
description VLAN to xxxxxxx
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.255.0
ip access-group 101 in
ip nat enable
interface FastEthernet0/0.5
description VLAN to yyyyyyy
encapsulation dot1Q 5
ip address 10.1.5.1 255.255.255.0
ip access-group 105 in
ip nat enable
interface FastEthernet0/0.50
description VLAN to Global Handoff
encapsulation dot1Q 50
ip address 50.50.50.17 255.255.255.240
ip access-group 150 in
interface FastEthernet0/0.99
description VLAN to zzzzzzzzz
encapsulation dot1Q 99
ip address 10.1.99.1 255.255.255.0
ip access-group 199 in
ip nat enable
interface FastEthernet0/1
ip address 50.50.50.2 255.255.255.252
ip nat enable
John Blakley Mon, 12/09/2013 - 05:50
  • Purple, 4500 points or more
With nat, there has to be two interfaces involved. The two interfaces, that you have listed are fa0/0 and fa0/1 (minus the subinterfaces on fa0/0). That being said, the configuration that you have is not directional specific (the older way is using "ip nat inside" and "ip nat outside"). You have fa0/1 as nat enable, and according to what you're saying this is the exit interface. That's just half the puzzle. You still need an "inside" interface which is where "ip nat enable" would come into play on your subinterface. Since that doesn't exist, this interface would NOT nat out as the 50.50.50.2 address.
HTH,
John
*** Please rate all useful posts ***
