12-09-2013 02:40 AM
All Experts,
I have configured remote vpn server on ASA 5510.
All the remote vpn clients are able to login to remote vpn server.
The issue is that only first vpn client can ping to the internal network and the rest of the clients cannot ping even though they are able to login.
Could you please help to find out what's wrong with my configuration?
Please refer to the below configuration.
Thanks.
ciscoasa#sh run
ASA Version 8.0(2)
hostname ciscoasa
domain-name test.com
enable password S3tnQLXTAbsdcawi encrypted
names
interface Ethernet0/0
description *** INTERNAL CONNECTION ***
nameif inside
security-level 100
ip address 10.215.1.1 255.255.255.0
interface Ethernet0/1
description *** WAN CONNECTION ***
nameif outside
security-level 0
ip address 210.x.x.x 255.255.255.252
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
clock timezone EST 10
dns server-group DefaultDNS
access-list outside_access_in extended permit icmp any any
access-list inside_access_in extended permit icmp any any
access-list NONAT extended permit ip 10.0.0.0 255.0.0.0 10.215.2.0 255.255.255.0
pager lines 24
logging enable
logging monitor debugging
logging buffered debugging
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
ip local pool VPNPOOL 10.215.2.1-10.215.2.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm506.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 210.x.x.x 1
route inside 10.0.0.0 255.0.0.0 10.215.1.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 10.215.0.0 255.255.0.0 inside
http 192.168.1.0 255.255.255.0 management
http redirect outside 80
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set RA-TS esp-3des esp-sha-hmac
crypto dynamic-map DYN_MAP 10 set transform-set RA-TS
crypto map VPN_MAP 30 ipsec-isakmp dynamic DYN_MAP
crypto map VPN_MAP interface outside
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 3600
no crypto isakmp nat-traversal
ssh 10.0.0.0 255.0.0.0 inside
ssh timeout 10
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
group-policy it-policy internal
group-policy it-policy attributes
wins-server value 10.215.1.11
dns-server value 10.215.1.12
vpn-idle-timeout 30
username testuser password k83iXWPan0Gg1s04 encrypted
username admin password TOyVyM6G6TXcuQ5w encrypted privilege 15
username user password enq05bKrudsJMMBu encrypted
tunnel-group itvpnclient type remote-access
tunnel-group itvpnclient general-attributes
address-pool VPNPOOL
default-group-policy it-policy
tunnel-group itvpnclient ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:6da9a4e00b5e6e1a914ec571becaf38f
: end
12-09-2013 08:11 PM
Hi Craig,
Try enabling NAT-T , you have it disabled, try that and let us know e.g crypto isakmp nat-traversal 20
troublesghooting reference
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
12-10-2013 05:57 AM
Hi Gorge,
Thanks for your advice.
I will try that and let you know the update.
Craig
12-11-2013 05:53 AM
Hi Gorge,
I am able to ping from any remote client after enabling crypto isakmp nat-traversal 20.
Thank you so much for your advice.
Hi William,
Thanks for your advice too even though I did not need to add "inspect icmp" under class inspection_default.
Appreciate for your help.
Craig
12-10-2013 07:54 AM
You might also try adding inspect icmp under your class inspection_default policy map.
