Warning message
Cisco ASA 5505 2 ISP VPN redundancy
Dec 9th, 2013
Good day. Faced with the following problem:
There are two offices - main and remote
Main- 2 ISP
Remote - 1 ISP
Currently working vpn site-to-site
I want to arrange automatic switching vpn channel, if the main office in the main
I have set up automatic switching through the Internet SLA
Vpn configure failover if the main provider fails.
The configuration file
Main
ASA Version 9.1(2)
hostname ***
enable password tX0R5vfFlkP6OgXI encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 3
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan2
description Main ISP
nameif ISP1
security-level 0
ip address *** 255.255.255.128
interface Vlan3
description Backup ISP
nameif ISP2
security-level 0
ip address *** 255.255.255.248
boot system disk0:/asa912-k8.bin
ftp mode passive
clock timezone GMT 0
dns domain-lookup ISP1
dns server-group DefaultDNS
name-server ***
name-server ***
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network FT
subnet 192.168.0.0 255.255.255.0
object network BFG
subnet 192.168.1.0 255.255.255.0
object network obf_any-01
object network obj_any-01
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
protocol-object udp
protocol-object esp
protocol-object tcp
access-list outside_cryptomap_1 extended permit object-group DM_INLINE_PROTOCOL_1 192.168.1.0 255.255.255.0 object FT
pager lines 24
logging enable
logging asdm errors
mtu inside 1500
mtu ISP1 1500
mtu ISP2 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,ISP1) source static BFG BFG destination static FT FT no-proxy-arp route-lookup
nat (inside,ISP2) source static BFG BFG destination static FT FT no-proxy-arp route-lookup
nat (inside,ISP1) dynamic interface
nat (inside,ISP2) dynamic interface
route ISP1 0.0.0.0 0.0.0.0 *** 1 track 2
route ISP2 0.0.0.0 0.0.0.0 *** 10
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
http *** 255.255.255.255 ISP1
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 55
type echo protocol ipIcmpEcho 8.8.8.8 interface ISP1
num-packets 5
frequency 10
sla monitor schedule 55 life forever start-time now
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 2 match address outside_cryptomap_1
crypto map outside_map 2 set peer 195.160.165.212
crypto map outside_map 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 2 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map interface ISP1
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable ISP1
crypto ikev2 enable ISP2
crypto ikev1 enable ISP1
crypto ikev1 enable ISP2
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
track 2 rtr 55 reachability
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh *** 255.255.255.255 ISP1
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tftp-server inside 192.168.0.1 255.255.255.0
webvpn
anyconnect-essentials
group-policy GroupPolicy_*** internal
group-policy GroupPolicy_*** attributes
vpn-tunnel-protocol ikev1 ikev2
username admin password kBPqc6LkJSUeMLlZ encrypted privilege 15
tunnel-group *** type ipsec-l2l
tunnel-group *** general-attributes
default-group-policy GroupPolicy_***
tunnel-group *** ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:03fe022c0296fea219aecb51aeec0977
: end
Remote
ASA Version 9.1(2)
hostname ***
enable password tDf.m22oBzmna4Cu encrypted
passwd RLPMUQ26KL4blgFN encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.246 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ftp mode passive
clock timezone GST 4
dns domain-lookup outside
name-server ***
object network BFG
object network NETWORK_OBJ_192.168.10.0_24
subnet 192.168.10.0 255.255.255.0
object network FT
object network NETWORK_OBJ_192.168.0.0_24
access-list outside_cryptomap extended permit ip object FT object BFG
pager lines 24
logging enable
logging asdm errors
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
nat (inside,outside) source static FT FT destination static BFG BFG no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 *** 1
http server enable
http *** 255.255.255.255 outside
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer ***
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map0 interface outside
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh *** 255.255.255.255 outside
ssh timeout 40
console timeout 0
dhcpd option 3 ip 192.168.10.1
dhcpd dns 192.168.10.1 interface inside
dhcpd domain ftprint.local interface inside
ntp server 85.114.26.194 source outside
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
username admin password uJzyG7vYLN1SRT7z encrypted privilege 15
tunnel-group 123 type ipsec-l2l
tunnel-group 123 general-attributes
default-group-policy GroupPolicy1
tunnel-group 123 ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
Cryptochecksum:e487aeefa21c38d103ea7d0230879d58
: end
