Updating MGCP Router/Gateway in CUCM
Mark VandeVere
I may have searched in all the wrong ways, but am not finding anything that matches
We just replaced 10 28XX gateways with 29XX gateways. They all run MGCP. While they all work under their prior CUCM configuration with the 28XX model shown, I'd like to keep all that up to date.
Is there a way to make a change to the router model without building a new one and deleting the old one, or is this it for me?
Jaime Valencia
No way to change the model, you need to recreate them using the new ISR G2 model.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
I was pretty sure that I hadn't missed anything, but was hoping Thanks!!
Hi Mark,
Please check below link, might be helpful to you.
https://supportforums.cisco.com/docs/DOC-33875
Nishant Savalia
Regards, Nishant Savalia
