Warning message
Cisco Secure ACS is not reporting events in the Administration Tacacs
Answered Question
Dec 9th, 2013
Does anybody knows what's the cause of there is no register events in the administration tacacs,
The last week there was no events in the administration and accounting tacacs, after a server reboot the accounting was reporting events but the administration is not reporting anything
Does anybody knows what's the cause of there is no register events in the administration tacacs?
The version is the next:
Cisco Secure ACS: 4.1.1.24.2
Appliance Management Software: 4.1.1.24.2
Appliance Base Image: 4.1.1.5
Thanks for your help
Correct Answer by edwjames about 3 years 8 months ago
Ricardo,
You can refer to this:
https://supportforums.cisco.com/message/846108?referring_site=bss&channel=bdp#846108
Defect:
https://tools.cisco.com/bugsearch/bug/CSCsg97429/?reffering_site=dumpcr
If you do not find the fixed patch on CCO, I would recommend you to upgrade to 4.2 (the supported ACS).
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
Overall Rating: 5 (2 ratings)
Correct Answer
edwjames Mon, 12/09/2013 - 10:17
  • Silver, 250 points or more
Ricardo,
Defect:
--Dalai Lama**
Ed
RICARDO SANCHEZ Mon, 12/09/2013 - 10:57
Edward
Thanks for your reply.
I serch in the 4.1.1.24  but there is not a patch for that version in the download software, I think the best opcion will be to upgrade the server.
