Warning message
Two ASA IPVPN tunnel ikev1 and ikev2
Answered Question
Dec 9th, 2013
Dear
I have using 2 ASA 5510 to make IPVPN tunnel.  From my experience.  I tried to used ONLY ikev1 are working fine. or I tried to used ONLY ikev2 are working fine for the tunnel connection.  So, any suggestion for me to keep using ikev1 or need to change to ikev2 instead?
Correct Answer by Julio Carvajal about 3 years 8 months ago
Hello Alan,
Yes, you can still do it.
I mean I recommend to start using IKEv2 as you have multiple benefits but it's not a MUST to do it. It will not be a secuarity breach to still use Ikev1.
And for your other question, yes you can terminate both IKEv 1 and IKEv2.
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Not sure I understand your question.
Are u asking if u need to move to IKEV 2 or stay on 1???
If that s the question then are fine on v1. Of course as you are aware of there are several benefits over running Ikev2 but you could still run v1.
Sent from Cisco Technical Support Android App
Overall Rating: 5 (2 ratings)
Correct Answer
Julio Carvajal Mon, 12/09/2013 - 19:18
  • Purple, 4500 points or more
alan-wong Mon, 12/09/2013 - 19:28
Hi, I can make connection for both either ikev1 or ikev2.  I am not sure is that any security reason need to change to ikev2.  Thank you for your answer.  I will keep in ikev1 as you said it is fine on v1.  thank you very much.
Correct Answer
Julio Carvajal Mon, 12/09/2013 - 19:31
Hello Alan,
Jcarvaja
alan-wong Mon, 12/09/2013 - 19:35
HI Jcarvaja
May I know the multiple benefits include any speed increase from opeartion prespective ?
Julio Carvajal Mon, 12/09/2013 - 19:37
That's one of the most important actually.
I will provide you a great post about it  where Cisco talks about Why should we all migrate
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080bca116.shtml
Let me know if u have any other question bud
Jcarvaja
Related Content
