Warning message
3602i Site Survey Question
Dec 10th, 2013
Hello guys,
I have some question about site surveying using Cisco 3602i.  Since I started using the 3602, I found the 5GHz signal very weak (see attached). I was standing probably 5 - 6ft from the AP and the 5GHz RSSI was in the range of -60 -  -51dBm.
I have the AP radios configured at 14dBm. There was a couple of 5GHz from the neighbor, but it should not be a problem since those neighbor APs are 3 floors below and the signal was very weak from where I was standing.
Also, what is the power level should I configure the AP for .11AC site survey? Should I still configure the powel to 25mW for both radios?
In addition, what is the deployment ratio for LBS using the WSSI? I know for the 3602i  wIPS WSSI module, it is 5:2, but what about LBS?
Overall Rating: 3.5 (2 ratings)
Scott Fella Tue, 12/10/2013 - 05:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Make sure you using a unii-3 channel as unii-1 has lower TX power and unii-2 you might hit DFS. I still survey at 25mW also. Make sure the AP doesn't have a bad radio in it also. You never know.
Location based surveys is the same as before and doesn't change because you want to us AC. If you wanted to guarantee AC, you would have a very high density deployment. LBS doesn't require AC and only requires triangulation from 3 AP's at a -75dbm or better.
steelinquisitor Tue, 12/10/2013 - 05:51
Scott,
I was using channel 165 on the picture I attached to my first post and I tried other UNII 3 channels as well, but I am getting really weak signal from 3602. I have multiple 3602 that I converted to thick for site surveying, and all of them were very similar in regards to 5GHz signal.
Do you think there is something wrong with my 3602i's ?
How do I check the for bad radio?
Scott Fella Tue, 12/10/2013 - 05:59
  • Hall of Fame,
    2017 Wireless
Try using 149 or 161... I have never used 165.  Also, I would see how far out the 5ghz goes until you hit your survey requirement which is -65 to -72 depending.  The 2.4ghz of course will have better coverage, but seeing what your seeing doesn't bother me unless the signal drops out when in another room.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
steelinquisitor Tue, 12/10/2013 - 10:07
I will test that pence I get back to the office. I don't my survey kit with me at the moment.
Scott, I have another question. What do you use or recommend for RSSI value for the wIPS survey. This is going to be with 3702 with WSSI module.
What is going to be the AP coverage for the wIPS survey? Is one, two or three AP coverage?
Scott Fella Tue, 12/10/2013 - 13:18
  • Hall of Fame,
    2017 Wireless
wIPS design is the same no matter what access point you choose. Take a look at the following link.
http://www.cisco.com/en/US/docs/wireless/technology/wips/deployment/guid...
vlad.mihailov Tue, 12/10/2013 - 10:57
Check your wireless NIC card, you may have an issue with it. I have recently ran in to this when surveiing with a wireless card attached to an USB hub to the top of my laptop's lid. Internal card (Intell 6300-series) would show 8 dB difference with the external card (Orinoco Proxim) :-(
steelinquisitor Tue, 12/10/2013 - 11:07
I did some testing before comparing the built-in wireless NIC on my laptop and my Proxim 8494. And found that the Proxim was -8 to -10dB higher than my built-in wireless card. For surveying, I only use the Proxim card.
vlad.mihailov Tue, 12/10/2013 - 15:13
Ironically my Orinoco card would show lower results versus Intel. However that depends on where I clip my USB hub too. In the spot above the lid it would show somewhat similar results, when positioned behind the lid it showed lower.
George Stefanick Tue, 12/10/2013 - 18:32
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
I hate when you see this big of a gap. Im a fan of the proxim USB. Take the safe way and survey at 25mW or even 12.5 mW at the AP to give you room.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
steelinquisitor Tue, 12/10/2013 - 20:13
I also have noticed that once I set my dot11radio0 to 14dBm and when I do a show run, it bumps up to 16dBm. Has anyone have this issue?
Scott Fella Tue, 12/10/2013 - 20:25
  • Hall of Fame,
    2017 Wireless
I have not seem that, but as far as AirMagnet, some versions did have issues like what you are seeing. I always check my Proxim card with my builtin wireless card. If you install the AirMagnet drivers it suppose to calibrate the card. You can manually calibrate the card or just call up AirMagnet support.
Florin Barhala Tue, 12/10/2013 - 23:11
  • Bronze, 100 points or more
Hi guys,
Sorry for being a bit off-topic. When doing Site Survey, you're using another software over an existing already deployed wireless infrastructure (APs+WLC)?
Next to that, from where you can tune APs db or mW? Is it from WLC: ... Tx Power Level Assignment option or are you doing this on the Software Survey App?
Scott Fella Wed, 12/11/2013 - 03:47
  • Hall of Fame,
    2017 Wireless
You can do a post site survey to verify coverage on an existing wireless environment. Yes you would use a tool to capture this information, but any tweaking is done on the WLC side.
vlad.mihailov Wed, 12/11/2013 - 08:54
You are adjusting transmit power (Cisco does it in Levels, each level is half power from the adjacent one). Then, assuming the software you use is correctly representing data (that is the topic of this thread) you register received strength with software and figure out if your results match targets.
steelinquisitor Wed, 12/11/2013 - 06:13
Scott,
I selected the Proxim card in the manual calibration and the RSSI got worse. Flukes' recommendation is no calibration which seems like the default.
Scott Fella Wed, 12/11/2013 - 07:04
  • Hall of Fame,
    2017 Wireless
They always recommend defaults, but if you notice a bug difference, then something is wrong. We typically engage AirMagnet support when we discover issues like this.
steelinquisitor Wed, 12/11/2013 - 07:28
Basically, the built-in wireless NIC on my laptop (Dell E6410) and the Proxim card should provide same value of RSSI. If not at least very close value.
vlad.mihailov Wed, 12/11/2013 - 08:51
"I always check my Proxim card with my builtin wireless card." now that is a great advise and that is what I am doing now. Fortunately I spotted the descrepancy when it was still easy to address.
AirMagnet support didn't really have anything to say about it. I was surprised also that if I'd run a capture with Proxim, then would choose a different card to interprite the survey results the difference was huge!! When I asked AirMagnet support about that they showed me they have the same huge difference at their end and thought this to be a bug.
Strange world..
