1142 AP unable to join WLC 7500, corrupted flash?
Dec 10th, 2013
Anothe issue I found today, managed to reinstall the AP which crashed into the ap: prompt. However, when it boots up and joins the WLC, it tries to download the latest image from controller and stops midway. After that not able to access flash system any longer.
Is there a way to clear the corrupted blocks? fsck command keeps showing these blocks below as corrupted. Anyone knows?
Please help advice.
Output during bootup:
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
RQDC, RFDC : 0x80000036, 0x00000209
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
flashfs[0]: found corrupted block[128] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[129] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[130] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[131] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[132] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[133] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[134] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[135] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[136] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[137] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[138] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[139] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[140] (byte 504, sector 61), fixing...
flashfs[0]: found corrupted block[141] (byte 504, sector 61), fixing...
flashfs[0]: 12 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 6863360
flashfs[0]: Bytes available: 25521664
flashfs[0]: flashfs fsck took 42 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 30:f7:0d:d8:c4:1c
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...########################################################
*Mar  1 00:00:28.504: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:27 by prod_rel_team
*Mar  1 00:00:28.549: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:28.549: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Mar  1 00:00:28.563: %PARSER-4-BADCFG: Unexpected end of configuration file.
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:29.517: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:48.152: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560X-48P (7081.0595.9e2d)
*Mar  1 00:01:01.918: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.1.1.50, mask 255.255.254.0, hostname AP30f7.0dd8.c41c
*Mar  1 00:01:12.801: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.20.1.1 obtained through DHCP
*Mar  1 00:01:12.801: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:12.890: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:22.892: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 10 11:36:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.20.1.1 peer_port: 5246
*Dec 10 11:36:51.693: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.20.1.1 peer_port: 5246
*Dec 10 11:36:51.694: %CAPWAP-5-SENDJOIN: sending Join Request to 10.20.1.1
examining image...
extracting info (288 bytes)
Image info:
    Version Suffix: k9w8-.152-4.JA1
    Image Name: c1140-k9w8-mx.152-4.JA1
    Version Directory: c1140-k9w8-mx.152-4.JA1
    Ios Image Size: 10025472
    Total Image Size: 10220032
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: C1140
    Wireless Switch Management Version: 7.5.102.0
Extracting files...
c1140-k9w8-mx.152-4.JA1/ (directory) 0 (bytes)
extracting c1140-k9w8-mx.152-4.JA1/T2.bin (8080 bytes)
*Dec 10 11:36:56.69
extracting c1140-k9w8-mx.152-4.JA1/img_sign_rel_sha2.cert (1371 bytes)
extracting c1140-k9w8-mx.152-4.JA1/8001.img (186308 bytes)4: %CAPWAP-5-SENDJOIN: sending Join Request to 10.20.1.1perform archive download capwap:/c1140 tar file
*Dec 10 11:36:56.783: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
extracting c1140-k9w8-mx.152-4.JA1/img_sign_rel.cert (1375 bytes)
extracting c1140-k9w8-mx.152-4.JA1/file_hashes (3760 bytes)
extracting c1140-k9w8-mx.152-4.JA1/final_hash.sig (513 bytes)
extracting c1140-k9w8-mx.152-4.JA1/T5.bin (23836 bytes)
extracting c1140-k9w8-mx.152-4.JA1/final_hash (141 bytes)
*Dec 10 11:37:16.261: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3560X-48P (7081.0595.9e2d)
extracting c1140-k9w8-mx.152-4.JA1/info (288 bytes)
extracting c1140-k9w8-mx.152-4.JA1/c1140-k9w8-mx.152-4.JA1 (9827394 bytes)
*Dec 10 11:38:56.780: %CAPWAP-3-ERRORLOG: Invalid event 48 & state 10 combination.
*Dec 10 11:38:56.780: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message. Event 48, state 10
*Dec 10 11:38:56.780: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Dec 10 11:38:56.780: %CAPWAP-3-ERRORLOG: Failed to process timer message.
flashfs[2]: writing to flash handle 0x1A31D10, device 0, offset 0x11E0000, length 0x208: Operation Failed
flashfs[2]: sector ptr: {0x8F, 0x3D}
flashfs[2]: filesystem marked down.  Use "fsck" to recover.
%Error writing flash:/update/c1140-k9w8-mx.152-4.JA1/c1140-k9w8-mx.152-4.JA1 (I/O error)
*Dec 10 11:44:59.083: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:44:59.083: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:44:59.083: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:44:59.083: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:01.960: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:45:01.960: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:45:01.960: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:45:01.960: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:05.020: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:45:05.020: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:45:05.020: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:45:05.020: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:08.080: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:45:08.080: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:45:08.080: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:45:08.080: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:11.140: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:45:11.140: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:45:11.140: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:45:11.140: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:14.200: %CAPWAP-3-ERRORLOG: Failed to store image.
*Dec 10 11:45:14.200: %CAPWAP-3-ERRORLOG: Image data: Failed to decode image data message element.
*Dec 10 11:45:14.200: %CAPWAP-3-ERRORLOG: Failed to decode Image data request.
*Dec 10 11:45:14.200: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 15 state 10.
*Dec 10 11:45:44.791: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceed., 1)x(CAPWAP_ECHO_REQUEST
*Dec 10 11:45:44.791: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.20.1.1:5246
*Dec 10 11:45:44.795: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec 10 11:45:44.797: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Dec 10 11:45:44.797: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Dec 10 11:45:54.821: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec 10 11:45:55.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.20.1.1 peer_port: 5246
*Dec 10 11:45:55.694: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.20.1.1 peer_port: 5246
*Dec 10 11:45:55.695: %CAPWAP-5-SENDJOIN: sending Join Request to 10.20.1.1
Unable to create temp dir "flash:/update"
Download image failed, notify controller!!! From:7.5.1.73 to 7.5.102.0, FailureCode:7
*Dec 10 11:46:00.695: %CAPWAP-5-SENDJOIN: sending Join Request to 10.20.1.1perform archive download capwap:/c1140 tar file
*Dec 10 11:46:00.784: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Dec 10 11:46:00.785: capwap_image_proc: encounter flash problem, retry here
*Dec 10 11:46:00.785: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Dec 10 11:46:00.786: capwap_image_proc: encounter flash problem, retry here
Overall Rating: 5 (2 ratings)
Scott Fella Tue, 12/10/2013 - 06:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I would look at what's in the flash and delete any error files and images. I would upload a new rcv image using the archive download command.
Jagan1976 Tue, 12/10/2013 - 07:09
Hi Scott,
Yes I have formatted the flash and made sure nothing inside. Then, installed the recovery image without any problems.
However the corrupted block info keeps coming up whenever rebooted.
Once it locks up the flash when the image download fails, I am not able to invoke any other commands.
Scott Fella Tue, 12/10/2013 - 07:12
  • Hall of Fame,
    2017 Wireless
The flash might be bad... Probably is. So if you have a support contract, you can possible RMA that AP. There is no way to fix it if it's a hardware issue.
Scott Fella Tue, 12/10/2013 - 06:54
  • Hall of Fame,
    2017 Wireless
Here is the command
https://supportforums.cisco.com/docs/DOC-18268
Scott Fella Tue, 12/10/2013 - 09:25
  • Hall of Fame,
    2017 Wireless
You might want to refernce this thread also... might help.
https://supportforums.cisco.com/thread/2255904?tstart=0
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Related Content
