12-10-2013 08:10 AM - edited 03-07-2019 05:01 PM
Greetings-
My company purchased a SPA-2X1GE-V2 card to be used on our 7606 router. The 7606 has a '2 port adapter Enhanced FlexWAN' module (WS-X6582-2PA). I tried installing the card into the module and it doesn't seem to fit. I take it that these two are not compatible. I tried looking through the 2SPA-2X1GE-V2 data sheet and can't find what this card works with, besides the fact that it's compatible with a 7606. Can someone assist me with figuring-out which module will work with the 2SPA-2x1GE-V2?
Thanks in advance!
Solved! Go to Solution.
12-10-2013 10:53 PM
I believe your module makes use of the port adapters from the old 7204/7206(VXR) routers. What you need seems to be a SIP-400:
12-10-2013 10:53 PM
12-11-2013 03:47 AM
Thanks for the reply and locating the link to the SIP-400 info page ... makes sense.
