Migrating PIX 501 configuration to ASA 5515-x configuration
Answered Question
Dec 10th, 2013
              I have been working on this migrating from a PIX 501 to ASA 5515-x. I have been greatly helped by a Cisco support team member. They gave me
  the instructions of how to migrate after I showed them the "run" config of the PIX and ASA. Upon entering the info to the ASA I ran into a problem with
  one of the command strings. It seems that the command "static", when used in the string "nat (inside,outside) static etc" is no longer used in ASA.
  I just want to "mirror" the PIX config to the ASA. I did recieve from our NEW ISP, the info to plug in the ASA for the fiber optic line that is being installed
  now. My questions are: 1. why doest the "static" work in ASA and what is the correct syntax? 2. I will post the NEW ip info for the new fiber line, instead
  of mirroring the PIX, how would I just plug the NEW info in the ASA?.
     Joseph
     Here is what I sent the cisco rep first...
OrthoPIX# sh startup-config
: Saved
: Written by enable_15 at 11:32:25.032 UTC Mon Dec 9 2013
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password NDa1RppHr2jz7Cnk encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname OrthoPIX
domain-name sbcglobal.net
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list outside permit tcp any host 66.xxx.xxx.xxx eq 3389
access-list 101 deny ip 10.10.10.0 255.255.255.0 10.10.15.0 255.255.255.0
access-list nonat deny ip 10.10.10.0 255.255.255.0 10.10.15.0 255.255.255.0
pager lines 24
logging on
logging buffered debugging
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 66.xxx.xxx.xxx 255.255.xxx.xxx
ip address inside 10.10.10.251 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp 66.xxx.xxx.xxx 3389 10.10.10.253 3389 netmask 255.25
5.255.255 0 0
access-group outside in interface outside
route outside 0.0.0.0 0.0.0.0 66.xxx.xxx.xxx 15
route inside 10.10.11.0 255.255.255.0 10.10.10.254 1
route inside 10.10.12.0 255.255.255.0 10.10.10.254 1
route inside 10.10.20.4 255.255.255.252 10.10.10.254 1
route inside 10.10.30.4 255.255.255.252 10.10.10.254 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:01:00 absolute
timeout xlate 0:01:00
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map transam 1 ipsec-isakmp
crypto map transam 1 match address 101
crypto map transam 1 set peer 65.69.93.98
crypto map transam 1 set transform-set myset
crypto map transam interface outside
isakmp key ******** address 65.69.93.98 netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 1000
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 167.1.162.167 255.255.255.255 outside
ssh timeout 60
dhcpd ping_timeout 750
terminal width 80
Here is the original ASA config I sent...
Result of the command: "show run"
: Saved
ASA Version 8.6(1)2
hostname ciscoasa
names
interface GigabitEthernet0/0
nameif Port0/0
security-level 0
ip address dhcp setroute
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
pager lines 24
logging asdm informational
mtu management 1500
mtu Port0/0 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface Port0/0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
Cryptochecksum:c5af97904bf21e317a1006e9b3901aa1
: end
Here is what the Cisco rep said I should do to "mirror" both configs...
I am not sure what your situation with the "outside" interface is. The PIX has staticly configured IP address and default route while the ASA at the moment has DHCP.
I will consider that the ASA should use the same configuration as the PIX
PHYSICAL INTERFACES
nameif outside
ip address 66.136.x.x 255.255.255.248
no shutdown
nameif inside
ip address 10.10.10.251 255.255.255.0
STATIC ROUTES
route outside 0.0.0.0 0.0.0.0 66.136.xxx.xxx 15
STATIC PAT (PORT FORWARD)
object network STATIC-PAT-RDP
host 10.10.10.253
nat (inside,outside) static 66.136.x.x service tcp 3389 3389
EXTERNAL ACCESS-LIST
access-list outside permit tcp any object STATIC-PAT-RDP eq 3389
DYNAMIC PAT
nat (inside,outside) after-auto source dynamic any interface
NAT0 / NAT EXEMPT FOR L2L VPN
object network LAN
subnet 10.10.10.0 255.255.255.0
object network REMOTE-LAN
subnet 10.10.15.0 255.255.255.0
nat (inside,outside) source static LAN LAN destination static REMOTE-LAN REMOTE-LAN
L2L VPN CONFIGURATION
access-list L2L-VPN remark L2L VPN Encryption Domain
access-list L2L-VPN permit ip 10.10.10.0 255.255.255.0 10.10.15.0 255.255.255.0
crypto ipsec ikev1 transform-set DES esp-des esp-md5-hmac
crypto map transam 1 match address L2L-VPN
crypto map transam 1 set ikev1 transform-set DES
crypto isakmp identity address
crypto ikev1 policy
encryption des
hash md5
group 1
lifetime 1000
crypto ikev1 enable outside
tunnel-group 65.69.93.98 type ipsec-l2l
tunnel-group 65.69.93.98 ipsec-attributes
ikev1 pre-shared-key <presharedkey/PSK>
The above should be most of the configurations from PIX to the new ASA format
The line with "nat (inside,outside) static 66.136.x.x service tcp 3389 3389" the ASA has a problem with "static" in the command, the help says it's not used anymore. So what is the correct syntax?
Here is how the ASA looks now....
ciscoasa# sh run
: Saved
ASA Version 8.6(1)2
hostname OrthoPIX
names
mac-address 0009.e8bf.6edc
nameif outside
security-level 0
ip address 6x.xxx.xxx.xxx 255.255.255.xxx
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 1xx.xxx.xx.xx
name-server 1xx.xxx.xx.xxx
host 10.10.10.253
access-list outside extended permit tcp any object STATIC-PAT-RDP
access-list outside extended permit tcp any object STATIC-PAT-RDP eq 3389
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 6x.xxx.xxx.xxx 15
route inside 10.10.20.0 255.255.255.0 10.10.10.254 1
route inside 10.10.30.0 255.255.255.0 10.10.10.254 1
user-identity default-domain LOCAL
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:201bf8315b82ffb0f158046489b5f512
: end
What am I doing wrong?, I know it's me because I'm still "rusty" on the ASA commands. Also, here is the new info for the new ip network we are recieving....
WAN IP: 12.XXX.XXX.XXX
Host Router Name: <HOSTNAME>
New IP Block: 12.XXX.XXX.XXX/28
Default Gateway GE-0/0: 12.XXX.XXX.XXX
Your 1st Network Device: 12.XXX.XXX.XXX
Subnet Mask: 255.255.255.XXX
DNS Resolvers: 12.XXX.XXX.XXX    12.XXX.XXX.XXX
Usable IP's: 12.XXX.XXX.XXX thru XXX
What do I need to do in order to just use the NEW ip info instead of the OLD PIX config info?
  Joseph
Correct Answer by Jouni Forss about 3 years 8 months ago
From your earlier messages I gathered that you were allocated a small public subnet from the ISP providing the fiber connection? Or is it a single IP address from the subnet only?
You should simply configure the IP address to the current "outside" interface with the "ip address" command like I described above. You should also change the default route to point to the new ISP connections gateway IP address with the "route outside 0.0.0.0 0.0.0.0 " command I mentioned above.
Your change also involved changing the NAT IP address in the RDP Static PAT configuration since it uses an IP address from the original. Also mentioned this in the above post.
These are naturally best done on site since you naturally would loose any remote management connection to the ASA while changing the IP addresses and routes
With regards to the DNS. You dont really need to tell the ASA the DNS servers unless you use the ASA as a DHCP server for the LAN users. The new ISP DNS server should be configured on the device that currently gives IP addresses to the LAN hosts or if staticly configured then it would need to be changed on the actual hosts.
- Jouni
Seems the IP address you are using is actually the same IP address that is configured in your "outside" interface.
Enter this command under the "object" instead.
  nat (inside,outside) static interface service tcp 3389 3389
The parameter "interface" will tell the ASA to use the "outside" interface IP address as the NAT IP Address.
- Jouni
The Static PAT (Port Forward) that was done in the old configuration format with the "static" command is done in the following way in the new configuration. I mentioned this in the previous discussion
It seems to me that you have not entered the "nat" command under the "object network STATIC-PAT-RDP"
host 10.10.10.253
If the ASA has not accepted the "nat" command it might mean that you entered it outside the "object" configuration mode. You first have to move under the "object"
Then you enter the "nat" command next
Then again you mention that your ISP is changing so you wont be able to use the above public IP address anymore. You have to replace it with a new IP address
There is really nothing special with changing the configurations of your external interface for the new ISP
The below first removes the current IP address from the interface and configures the new public IP address from the ISP. It then removes the old default route and enters the new default route. Naturally you will have to use the actual/correct IP address in your commands.
no ip address 6x.xxx.xxx.xxx 255.255.255.xxx
ip address 12.x.x.a 255.255.255.x
no route outside 0.0.0.0 0.0.0.0 6x.xxx.xxx.xxx 15
route outside 0.0.0.0 0.0.0.0 12.x.x.y
You will also need to change the Static PAT (Port Forward) configurations public IP address from before
Again we move under the "object" configuration mode and then remove the old "nat" command and enter a new "nat" command
no nat (inside,outside) static 66.136.x.x service tcp 3389 3389
nat (inside,outside) static 12.x.x.b service tcp 3389 3389
- Jouni
Overall Rating: 5 (3 ratings)
Correct Answer
Jouni Forss Tue, 12/10/2013 - 09:40
host 10.10.10.253
- Jouni
orthostlgrp1 Tue, 12/10/2013 - 10:11
Hello Jouni,
         Thanks you so much for your reply!, here is what happens when I follow the instructions you gave with the "nat"
  command under the "object" configuration....
OrthoPIX> enable
Password: ***********
OrthoPIX# config t
OrthoPIX(config)# obj
OrthoPIX(config)# object netwo
OrthoPIX(config)# object network S
OrthoPIX(config)# object network STATIC-PAT-RDP
OrthoPIX(config-network-object)# host 10.10.10.253
OrthoPIX(config-network-object)# nat (i
OrthoPIX(config-network-object)# nat (inside,o
OrthoPIX(config-network-object)# nat (inside,outside) static 66.xxx.xxx.xxx se$
ERROR: Address 66.xxx.xxx.xxx overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
Was I suppose to "activate" nat???
Joseph
Correct Answer
Jouni Forss Tue, 12/10/2013 - 10:14
- Jouni
orthostlgrp1 Tue, 12/10/2013 - 10:21
        Thanks again Jouni!, that was it!. Now I have to go on-site and test it out.
     Thank you so much!,
         Joseph
orthostlgrp1 Tue, 12/10/2013 - 16:13
      I'm starting to "see" what you meant by "what my "outside" consists of". The AT&T fiber guys came out and we speed tested the new network and everything is great. Now, when I plugged the "fibers" GE 0/0 into the ASA's GE 0/0 I have a
"amber light" showing on the "spd" side of the port. The Fiber's GE has a static IP tied to it. I don't think I have my configuration setup for the "fiber's static ip". So basically AT&T has a fiber router and it is going to deliver internet to my ASA. How should I setup my "outside" port to talk to THEIR "outside" port??? Also what is the correct command to input DNS into a router???
     Joseph
Joseph Green Tue, 12/10/2013 - 19:42
  Hello Jouni,
        Thinking about it further, when I tested the speedtest, I plugged my laptop in and entered basic ip info. I have yet to
configure a "Gateway or Router" to the ASA configuration. How would I go about configuring the ASA to point to a Gateway?.
    Joseph
Correct Answer
Jouni Forss Wed, 12/11/2013 - 06:03
- Jouni
Joseph Green Wed, 12/11/2013 - 06:26
  Hello Jouni,
             Thank you for your reply!, yes you are right. Last night after looking over all my configs and your notes I noticed
  my route wasn't configured properly to point to the ISP router from the ASA. I did change the NAT IP as well. Also, like
  you stated, the 2600 router that DHCP's the offices still had the OLD DNS ip's and not the new ones. After fixings configs
  and rebooting router, all is well now, so it seems. lol. Thank you for all your help and notes, I'm learning so much as an
  Admin working with Cisco equipment. Really apprecitate it!
  Thank you,
       Joseph
