Adding 7800 Phones on CUCM 8.6/9.1
Answered Question
Dec 10th, 2013
Hi folks,
We just bought a brand new 7821 Phone and wanted to test it internally in our labs.
We´ve downloaded the COP file mentioned in the Release Notes (cmterm-78xx.10-1-1-9.cop.sgn), restarted TFTP Service, even restarted the Server, but there is still not a single 78xx phone type showing up under the Phones list.
We have tested with the following versions:
8.6.2.20000-2
9.1.1.20000-5
The release notes state it should work with versions 8.5+.
Am I missing something? Do we need an additional package to make it work?
Javi
Correct Answer by Manish Prasad about 3 years 8 months ago
I think you need to install new device pack to enable new device support in cucm.
This link will help you to find the compatibility matrix . - http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_m...
Cucm 9.1 dev pack do not support 7821 , so you need to download for 8.6 at this link - http://software.cisco.com/download/release.html?mdfid=283782839&flowid=4... and test it.
Note- after installation cluster wide restart necessary.
Please rate if this help.
Overall Rating: 4.5 (5 ratings)
Correct Answer
Manish Prasad Tue, 12/10/2013 - 11:03
Aman Soi Tue, 12/10/2013 - 18:46
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Javi,
Can u please share show version active from the CUCM server where u have uploaded 7821 firmware ?
Hope u have uploaded latest DEVPack.
I find that there is one Device pack for Administration Capability only  for 7821/7841/7861 phone.Did u upload this also?
regds,
aman
fodermat Wed, 12/11/2013 - 08:06
Thanks Prasad, I was missing the device package. It Could have been specified in the RN...
Javi
Aman Soi Wed, 12/11/2013 - 08:27
    2017 IP Telephony
Hi Javi,
Just for sake of knowledge, did u upload Adminsitration Capability Device Pack as well?
If possible, please share show version active.
regds,
aman
Nico Be Sun, 12/15/2013 - 11:26
Does anybody know, whether the CUCM 9.1.2 supports the 7800 series natively (w/o dev pack)?
armin.wagenfueh... Thu, 01/30/2014 - 04:08
Hello Community, really no chance to activate only 78xx Phones on CUCM 8.6.2 w/o install the complete Device Package?
Armin
HTH, please rate all useful posts and right answers.
Manish Gogna Thu, 01/30/2014 - 04:24
  • Cisco Employee,
Hi Armin,
There is no other option at this moment other than installing the device pack.
Manish
armin.wagenfueh... Thu, 01/30/2014 - 04:42
Hi Manish, really thanks for your response. May be that is a option --- > At the Endpoint section 7800 I found this cop file regarding 78xx Phones. I install it, restart cluster, but still no 78xx entrys in device defaults. It seems it is only to install the software only files.
7821/7841/7861 SIP IP Phone load signed COP file - Compatible CUCM Versions: 8.5(1)+
I saw on Comp Matrix there is a Cisco Unified IP Phone 7821, 7841, and 7861 Administration Capability Only
What is Administration Capability Only?
The Goal is don´t touch the other Phoneloads and add only the possiblity to add 78xx Phones at 8.6.2.
Can I use Cisco Unified IP Phone 7821, 7841, and 7861 Administration Capability Only?
Armin
Manish Gogna Thu, 01/30/2014 - 04:53
  • Cisco Employee,
Hi Armin,
Its actually a firmware file, a device package is needed to enable a new device type to be added to callmanager.
Manish
andres.pasten Mon, 07/20/2015 - 12:04
There is no qed file to enable these 78XX phones, as it is available for 3905 phones?
3905 SIP IP Phone Enabler - Compatible CUCM Versions: 7.1(5)+
cmterm-3905-qed.9-2-1-0.cop.sgn
I ask this because we have several clusters, and device package is a mess for all other phones that have other firmwares running, and it requires a restart of the cluster.
TIA
Andres Pasten
Jaime Valencia Mon, 07/20/2015 - 12:07
  • Cisco Employee,
  • Hall of Fame,
    2011
No, there is no QED, there's only native support on the CUCM release, or DevPack.
johaas123 Thu, 03/06/2014 - 01:38
We do have a similar situation. We're running CUCM 8.5.1, we installed COP file (cmterm-78xx.10-1-1-9.cop.sgn) to support 78xx phone series. Thereafter we've checked Device Defaults and didn't find the new series. Thus we searched for similar probs and we found this article.. then we've installed the device pack for our version.
Now my question: Do we need to update other loads too before restarting the whole cluster?
The release notes of the device pack shows the latest device, load, and release versions that are compatible with CUCM device package release 8.5.1. The loads are newer than those we're running at the moment..
johaas
Aman Soi Thu, 03/06/2014 - 01:55
    2017 IP Telephony
Hi Johaas,
you need to upload the device pack along with loads in call manager servers in a cluster.
what exactly is the issue u are facing?
regds,
aman
Jaime Valencia Thu, 03/06/2014 - 07:04
  • Cisco Employee,
  • Hall of Fame,
    2011
The device pack will update all other phone FW version it contains, whether you like/want it or not, your only option is to take a screenshot of what you had, then install the DEVpack, go to the device defaults to change it back, then do the cluster reboot.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Alfredo Naranjo Tue, 07/29/2014 - 07:47
Hi Manish,
I have to prepare Device Pack for CUCM 9.1.2.10000-28, I think that I have to use this one:
Cisco Unified Communications Manager 9.1(2.11012) Device Package - Compatible UCM Version: 9.1
Release:9.1(2.11012)
Release Date:04/Nov/2013
File Name:cmterm-devicepack9.1.2.11012-1.cop.sgn
Size:889.11 MB (932301220 bytes)
MD5 Checksum:c7169244bef906d356fd7bf02d276ca5
But I have a question
Do I need to install firmware for 78XX series too?
regards.
Aman Soi Tue, 07/29/2014 - 08:01
    2017 IP Telephony
No.
Firmware is not required.
regds,
aman
heba00001 Fri, 11/13/2015 - 12:13
hi
i have the same  problem and  same  version , what happen with you ??, did you install the releas 9.1(2.11012) , and the problem of the registraton of 7821 ip phone solve without installation of frimware for 78XX series also in your cucm , please i need your advice and the steps that you did , thank you.
Jaime Valencia Sat, 11/14/2015 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    2011
The DevPack already contains FW for the new devices, read the README for instructions on how to install it
Mohammed Idris Sun, 12/06/2015 - 09:59
today I tried downloading the device pack and I got error message saying the file is not available for the download. Any idea what the issue is?
heba00001 Sun, 12/06/2015 - 23:04
hi Mohammed
that time when i try to download the file i got massage that i need service contract registered under my profile to downloaded , so i ask my network administrater to downlouded for me .
regards
heba
Placide Lysias NJAMI Thu, 06/19/2014 - 15:46
Hi Sir,
We just buy a Cisco UC540  with  CUCM 8.6 (see the cli output below). We need a support for IP Phone 7861
UC540#sh telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
  1. So how do we install the   cmterm-devicepack8.6.2.25126-1.cop.sgn    Device pack File ?  (I started the download now)
  2. How to we install the phone ?
Manish Gogna Fri, 06/20/2014 - 02:40
  • Cisco Employee,
The product that you have bought is used for CUCME ( callmanager express ), CUCM is built on MCS or UCS servers. Your UC540 is running CUCME 8.6 which does not support 78XX series of IP phones as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/gu...
You will require CME version 10.0 for supporting 78XX IP phones, please check the following
Manish
Placide Lysias NJAMI Fri, 06/20/2014 - 04:30
So sir, can i install CME 10.0  on my  UC540 system ?
If yes, please give me the steps to do it.  (I hope so, we already have the IP Phones !  sad)
bellow the IOS release :
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 10:17 by prod_rel_team
kfbaluyut17 Fri, 02/12/2016 - 01:33
Hi Manish,
I have a similar problem. From our devices, we already have some of the 88XX series (8831, 8841, 8851, 8861), but we need the 8845 firmware. Do I still need to install the whole device package for all of the 88xx series or do i just need the 8845 firmware now?
Thanks in advance for your reply. Thanks!!
Kenneth
Deepak Rawat Fri, 02/12/2016 - 03:42
  • Cisco Employee,
Well if you already have 88XX series (8831, 8841, 8851, 8861) phones running in your environment then that means the required Device Package is already installed on CM. Simply proceed with installing the 8845 FW and you should be good.
Deepak
