Warning message
USC C220 M3 ESXi Can't see a raid5
Dec 11th, 2013
Hello, i have a problem with UCS C220 M3 with 4 SATA drives and UCS-RAID-9266CV controller.
I try to install ESXi on this server.
- I have download Cisco customization *ISO ESXi image ( try different versions 5.0, 5.1,5.5)
- Setup CIMC, set ip parameters.
When the server booting - In system parameters press F2 select from Onboard SCU Storage SW Stack select Intel RSTe
then made raid 5 via CTRL I
Then I try download ESXi iso file on server via KVM Console. ESXi begin to install, then when selecting of Drives appears I can't see my storage there, ESXi can't recognize:
Then I try to disable Onboard SCU Storage Support, after this server can't see physical drives. It doesn't helped.
What could be wrong?
I hope for your help. Thank you.
Overall Rating: 5 (3 ratings)
Manuel Velasco Wed, 12/11/2013 - 09:36
  • Cisco Employee,
Hi Vassiliy,
From the screenshot you provided, I believe you are using embedded raid controller to configure raid.  Unfortunately the embedded controller is not support by ESXi, so the installation won’t be able to see the raid volume that you created with this controller. In this case you will need to use a PCI or mezzanine base controller for the installation.
Embedded MegaRAID Controller
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C220/install/raid.html#wp1028426
Supported Mezzanine and PCI controllers
Be kind and Mark as Answer if I helped.
Vassiliy Zatsepin Wed, 12/11/2013 - 09:41
Manuel, thank for you answer.
I don't undestand where in BIOS  I can choose not Embedded controller. See first screenshot. Its all I have to choose.
If I choose Disable Onboard SCU Storage Support (as it is written in datasheet) for using PCI controller, server doesn't see physical drives.
Thank you
Manuel Velasco Wed, 12/11/2013 - 09:46
  • Cisco Employee,
The embedded controller is a piece of hardware (embedded) to the motherboard of his server to disable the embedded controller in the bios you will need to disable the option Onboard SCU Storage Support.
If you remove the top cover of your server you will notice that the SAS cables are connected to two SAS port on the motherboard.  For this installation to work you need a PCI or Mezzanine base controller
Vassiliy Zatsepin Wed, 12/11/2013 - 10:23
Manuel, sorry for my importunity
I have open top cover, then I need unplug two SATA cables? I cant' see other PCI controller here.
You can see a foto below:
Manuel Velasco Wed, 12/11/2013 - 10:34
  • Cisco Employee,
Hi Vassiliy,
From the screenshot it looks like you that you don't have another PCI base raid controller. You will need to buy one and installed on this server.  When you get the new controller, you can connect sas cables to the new controller.
pictures of a PCI raid card
SAS cables on your server
Related Content
