Warning message
Showing Limited connectivity in Cisco 1000 Series Lightweight Access Points
Dec 12th, 2013
Hi Team,
We are facing issue in our 1000 series lightweight access point
Showing limited connectivity and not able to get the ip address for the associated clients(laptops)
pls help on the issue
I have attached the debug client command for ur reference.
The mac address of the client is 8c:70:5a:f3:70:ac
Sandeep Choudhary Thu, 12/12/2013 - 05:30
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Arun ,
Mian problem is , ur client is not getting IP from DHCP.
Check these:
1.did u configured the option 43?
2.did u enabled DHCP proxy on WLC?
Via CLI : config DHCP proxy enable
Via GUI: Controller>Advanced>DHCP
3.if WLC is in another subnet than DHCP then use IP helper command on switch.
4. In between firewall is there than check that one.
arun karthick Thu, 12/19/2013 - 04:12
Hi Sandeep,
In the same Access point some of the other users are connected and working fine.
But we are facing the issues with some clients and newly connected..
WISM version :
4.2.207.0
Sandeep Choudhary Thu, 12/19/2013 - 04:32
    2017 Wireless
HI Arun,
As per your logs...
Client stucked in DHCP Req. state.
Can u check if u have enough DHCP ip in DHCP scope?
Proxy enabled?
Please also provide the output of : debug client <mac address of client>
Dont forget to rate helpful posts.
arun karthick Thu, 12/19/2013 - 21:49
Hi Sandeep,
DHCP scope is fine for the clients.
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP received op BOOTREQUEST (1) (len 308, port 29, encap 0xec03)
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP selecting relay 1 - control block settings:
dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
dhcpGateway: 0.0.0.0, dhcpRelay: 10.237.156.2  VLAN: 704
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP selected relay 1 - 10.237.5.29 (local address 10.237.156.2, gateway 10.237.156.1, VLAN 704, port 29)
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP transmitting DHCP DISCOVER (1)
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP   xid: 0x97d279e0 (2547153376), secs: 7936, flags: 0
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP   chaddr: 8c:70:5a:f3:70:ac
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP   siaddr: 0.0.0.0,  giaddr: 10.237.156.2
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP sending REQUEST to 10x.237.156.1 (len 350, port 29, vlan 704)
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP selecting relay 2 - control block settings:
Thu Dec 12 17:53:27 2013: 8c:70:5a:f3:70:ac DHCP selected relay 2 - NONE
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP received op BOOTREQUEST (1) (len 308, port 29, encap 0xec03)
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP selecting relay 1 - control block settings:
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP selected relay 1 - 10.237.5.29 (local address 10.237.156.2, gateway 10.237.156.1, VLAN 704, port 29)
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP transmitting DHCP DISCOVER (1)
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP   xid: 0x4d3d0c34 (1295846452), secs: 0, flags: 8000
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP   chaddr: 8c:70:5a:f3:70:ac
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP   siaddr: 0.0.0.0,  giaddr: 10.237.156.2
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP sending REQUEST to 10.237.156.1 (len 350, port 29, vlan 704)
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP selecting relay 2 - control block settings:
Thu Dec 12 17:53:59 2013: 8c:70:5a:f3:70:ac DHCP selected relay 2 - NONE
(WiSM-slot10-1) >Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Association received from mobile on AP 00:0b:85:66:0c:50
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Applying site-specific override for station 8c:70:5a:f3:70:ac - vapId 1, site 'Corporate AP grouping', interface 'corporate-new'
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 DHCP_REQD (7) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1106)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Processing RSN IE type 48, length 22 for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Received RSN IE with 0 PMKIDs from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 DHCP_REQD (7) Change state to START (0) last state DHCP_REQD (7)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 START (0) Initializing policy
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state DHCP_REQD (7)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state DHCP_REQD (7)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:0b:85:66:0c:50
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac apfPemAddUser2 (apf_policy.c:212) Changing state for mobile 8c:70:5a:f3:70:ac on AP 00:0b:85:66:0c:50 from Associated to Associated
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Stopping deletion of Mobile Station: (callerId: 48)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Sending Assoc Response to station on BSSID 00:0b:85:66:0c:50 (status 0)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac apfProcessAssocReq (apf_80211.c:3888) Changing state for mobile 8c:70:5a:f3:70:ac on AP 00:0b:85:66:0c:50 from Associated to Associated
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac 0.0.0.0 Removed NPU entry.
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac dot1x - moving mobile 8c:70:5a:f3:70:ac into Connecting state
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Sending EAP-Request/Identity to mobile 8c:70:5a:f3:70:ac (EAP Id 1)
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Received EAPOL START from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:05 2013: 8c:70:5a:f3:70:ac Sending EAP-Request/Identity to mobile 8c:70:5a:f3:70:ac (EAP Id 2)
(WiSM-slot10-1) >
(WiSM-slot10-1) >Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAPOL EAPPKT from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received Identity Response (count=2) from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac EAP State update from Connecting to Authenticating for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac dot1x - moving mobile 8c:70:5a:f3:70:ac into Authenticating state
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Response state for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Processing Access-Challenge for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=111) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac WARNING: updated EAP-Identifer 2 ===> 111 for STA 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 111)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 111, EAP Type 3)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=112) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 112)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 112, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=113) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 113)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 113, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=114) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 114)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 114, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=115) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 115)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 115, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=116) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 116)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 116, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=117) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 117)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 117, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Req state (id=118) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP Request from AAA to mobile 8c:70:5a:f3:70:ac (EAP Id 118)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAP Response from mobile 8c:70:5a:f3:70:ac (EAP Id 118, EAP Type 25)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Processing Access-Accept for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Setting re-auth timeout to 3600 seconds, got from WLAN config.
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Station 8c:70:5a:f3:70:ac setting dot1x reauth timeout = 3600
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Creating a PKC PMKID Cache entry for station 8c:70:5a:f3:70:ac (RSN 2)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Adding BSSID 00:0b:85:66:0c:5f to PMKID cache for station 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: New PMKID: (16)
Thu Dec 12 17:54:19 2013:      [0000] d4 2e cb 91 05 81 01 7b 70 7b 7d d1 52 a0 f8 9d
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Disabling re-auth since PMK lifetime can take care of same.
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAP-Success to mobile 8c:70:5a:f3:70:ac (EAP Id 118)
Thu Dec 12 17:54:19 2013: Including PMKID in M1  (16)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Sending EAPOL-Key Message to mobile 8c:70:5a:f3:70:ac
   state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Entering Backend Auth Success state (id=118) for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received Auth Success while in Authenticating state for mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac dot1x - moving mobile 8c:70:5a:f3:70:ac into Authenticated state
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAPOL-Key from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAPOL-key in PKT_START state (message 2) from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Stopping retransmission timer for mobile 8c:70:5a:f3:70:ac
   state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile 8c:70:5a:f3:70:ac
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state DHCP_REQD (7)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:0b:85:66:0c:50
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 L2AUTHCOMPLETE (4) pemAdvanceState2 4256, Adding TMP rule
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 L2AUTHCOMPLETE (4) Adding Fast Path rule
  type = Airespace AP - Learn IP address
  on AP 00:0b:85:66:0c:50, slot 1, interface = 29, QOS = 0
  ACL Id = 255, Jumbo Frames = NO, 802.1P = 0, DSCP = 0, TokenID = 5006
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 L2AUTHCOMPLETE (4) Successfully plumbed mobile rule (ACL ID 255)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 4272, Adding TMP rule
Thu Dec 12 17:54:19 2013: 8c:70:5a:f3:70:ac 0.0.0.0 DHCP_REQD (7) Replacing Fast Path rule
Related Content
Trending Topics - Security & Network
