Warning message
MGCP BRI unregistered
Dec 12th, 2013
  • Blue, 1500 points or more
Peeps,
I am doing diagnostics on the following issue, the BRI interface on a 2900 series router is backhauled using MGCP. what I am seeing, is that the BRI enpoint in CUCM changes to "UNREGISTERED", causing outbound calls to fail. In those events, when looking at the actual BRI interface on the gateway itself. Layer1 is deactivated.However, layer 1 (and thus Layer 2) can be re-established by making an inbound call.  Which also re-registers the BRI end point on CUCM.  the alers we receive happen during nighttime, wich leads me to believe a time expires, either on the gateway end, or on the Telco end, bringing Layer 1 down.  My question is, is there any such thing, like a keepalive that can be sent from the gateway to the NTU (Telco), to keep the circuit up? (I know, I can set up some sort of outbound autodialer, but really this should work). I am not seeing this behaviour on any of our other locations here in Australia.
ISDN BRI0/0/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
ISDN related config:
network-clock-participate wic 0
network-clock-select 1 BRI0/0/0
isdn switch-type basic-net3
interface BRI0/0/0
description VNM AAPT BRI
no ip address
no logging event link-status
no snmp trap link-status
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn sending-complete
trunk-group pstn
hostname#sh ccm-m
MGCP Domain Name: hostname
Priority        Status                   Host
Primary         Registered               10..x.x.x
First Backup    Backup Ready             10x.x.x.1
Second Backup   None
Current active Call Manager:    10.x.x.x.
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            09:39:17 aesdt Dec 13 2013 (elapsed time: 00:00:10)
Last MGCP traffic time:         09:39:17 aesdt Dec 13 2013 (elapsed time: 00:00:10)
Last failover time:             00:29:46 aesdt Dec 13 2013 from (10.32.188.11)
Last switchback time:           00:33:46 aesdt Dec 13 2013 from (10.32.184.11)
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  10.32.188.11
    Current Link State: OPEN
    Statistics:
        Packets recvd:   2183
        Recv failures:   0
        Packets xmitted: 4363
        Xmit failures:   0
    BRI Ports being backhauled:
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: 1385946728-ac01c3ed-d5ef-454a-ae25-8dc15753ee95
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 3
          Download Successful          : 3
          Download Failed              : 0
          TFTP Download Failed         : 0
        Configuration Attempted        : 2
          Configuration Successful     : 2
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
CUCM: 8.6.2.23900-10
Cisco 2900 series: Version 15.0(1)M5
Please remember to rate useful posts, by clicking on the stars below.
Overall Rating: 3 (1 ratings)
Chris Deren Thu, 12/12/2013 - 15:07
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do yourself a favor and ditch MGCP for SIP, your life will be much simpler :-)
Chris
Dennis Mink Thu, 12/12/2013 - 16:06
Spot on, but that is not up to me in this case
Carlo Poggiarelli Thu, 12/12/2013 - 15:08
  • Green, 3000 points or more
Hi.
Can you try to assing a static TEI and see if it makes difference?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Aman Soi Fri, 12/13/2013 - 02:28
  • Purple, 4500 points or more
    2017 IP Telephony
Hi Mink,
Assigning static TEI could be possible , if Telco permits.
regds,
aman
