AAA/RADIUS server priority in WLC
Dec 16th, 2013
As of now I have our RADIUS server defined in both the WLAN and Flexconnect group. Do I need to define it in both? Which one is primarily used for authentication of users?
Philip
Rasika Nayanajith Mon, 12/16/2013 - 01:56
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Phillip,
When you configure AAA server under WLAN -> Security ->AAA server section that will take the precedance over any other configured AAA servr in the controller.
Typically you configure primary & secondary AAA server for FlexConnect AP group, to make it administratively easy to configurer it for multiple H-REAP/FlexConnect APs (simply you can add AP to the group which will get those radius config). You requires this if you have multiple AAA servers & in H-REAP standalone mode you require to use them.
This is some reference post with respect to WLC 7.0. code which may help you on this
http://mrncciew.com/2013/03/12/h-reap-with-radius/
Rasika
**** Pls rate all useful responses ****
Trending Topics - Security & Network
