Warning message
Jumbo Frames and DF bit
Answered Question
Dec 16th, 2013
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Unified Computing, Storage Networking
Enabling Jumbo Frames on UCS doesn't seem to set the DF bit ? correct ?
Can this be set by UCSM and/or CLI ?
Correct Answer by richbarb about 3 years 8 months ago
Once I did the test about the jumbo frames network performance and can't see any significant difference.
In that time I used a oracle RAC installed in the UCS and a NetApp Filer with DNFS configuration.
In the UCS you must configure MTU in two different places (QoS configuration and vNIC configuration).
In your test with df-bit flag enabled use the packet size maximum of 8972.
Overall Rating: 5 (1 ratings)
Walter Dey Mon, 12/16/2013 - 04:25
Thanks for this pointer
UCS customer uses Jumbo frames for NFS, connecting to a Netapp Filer which is in a different IP subnet.
He compared performance with standard Ethernet frame size and Jumbo frames, and didn't see any difference.
I therefore proposed to do a test from ESXi
vmkping -I vmk2 -d -s 9000 192.168.......
vmkping -I vmk2 -d -s 1500 192.168.......
which fails, however
vmkping -I vmk2 -s 9000 192.168.......
vmkping -I vmk2 -s 1500 192.168.......
works ok
Therefore, somewhere in the network between UCS and Netapp, there must be a problem.
It seems, that typical OS (e.g. ESXi) don't set the DF flag.
Correct Answer
richbarb Mon, 12/16/2013 - 04:36
  • Cisco Employee,
Walter Dey Mon, 12/16/2013 - 05:03
8970 was the solution ! Thanks Richard !
Related Content
