Warning message
Fabric Interconnect spare partition space utilization
Dec 16th, 2013
  • Silver, 250 points or more
hey, can someone tell me what the FI spare partition is for? Have a customer with 6120 FIs and on the B side 87% of the spare partition is used and is generating a fault.
I have removed old firmware packages and core dumps and tech support bundles but the spare partition utilized space doesn't change. The A side is around 65%.
Overall Rating: 5 (1 ratings)
Keny Perez Mon, 12/16/2013 - 11:08
  • Blue, 1500 points or more
Jeremy,
Could you please share the fault seen?
-Kenny
Anuj Thapa Mon, 12/16/2013 - 16:55
SSH to UCSM
#connect local b
# dir or ls
Check for Used Vs free Space and look for file named Fwm_trace_file and check if this is the file causing over utilization of the workspace.
More information on the defect below,
https://tools.cisco.com/bugsearch/bug/CSCuh88231/?reffering_site=dumpcr
Ps Btw nice blog you got there.
Walter Dey Tue, 12/31/2013 - 00:47
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Unified Computing, Storage Networking
I have seen this file Fwm_trace_file growing very big ? who is creating this file ? any debug plugin ?
padramas Tue, 12/31/2013 - 01:58
  • Cisco Employee,
fwm_trace_file issue happens only on 2.1.1f version. It is created when you initiate UCSM techsupport collection process.
It is safe to delete the file.
@Jeremy, please share the fault and UCSM version.
You can view the contents of spare partition from NX-OS context
(nxos)#  show system internal dir /spare/
Padma
michaelfrady Wed, 01/01/2014 - 21:41
I too have an issue with my /spare partition filling up.
When I use the following command:  show system internal dir /spare/coremgmt/logs
I can see that I have a ton of files.  How do I get to the /spare partition to delete these files?
padramas Wed, 01/01/2014 - 21:45
  • Cisco Employee,
Hello Michael,
UCSM version ?
Can you please share the output of following commands
connect local-mgmt
dir
dir  diagnostics
dir techsupport
dir cores
Padma
michaelfrady Wed, 01/01/2014 - 21:54
UCS Manager Version 2.1(2a)
I've already deleted files from the workspace and volatile location
dir
     cores
     /debug_plugin/
     diagnostics
     lost+found/
     techsupport/
dir cores
Usage for workspace://
291376128 bytes total
31024128 bytes used
245306368 bytes free
dir diagnostics
1 31 Jul 01 06:17:50 2012 diagnostics
31024128 bytes used
dir techsupport
1 22507520 May 14 10:58:55 2012 20120514105217_UCS01_UCSM.tar
31024128 bytes used
padramas Wed, 01/01/2014 - 22:28
  • Cisco Employee,
FI hardware model ?
can you please share the alert message regarding spare partition ?
michaelfrady Wed, 01/01/2014 - 22:32
6140XP
Description:  Disk usage for partition spare on fabric interconnect B exceeded 90%
Cause:  capacity-exceeded
It's currently at 92%
FI A is at 6%
padramas Wed, 01/01/2014 - 22:46
  • Cisco Employee,
On 6140, /spare is 4G partition used for system libraries.
Can you please open a TAC service request to further investigate it ?
