Prime Infrastructure 2.0 top cpu utilization
Answered Question
Dec 16th, 2013
                  We've recently installed PI2.0 and it is working well, with a small exception - the top cpu utilization only shows the wireless controllers.  is there a setting to adjust that to all devices or has anyone worked in a fix ?
thanks for your support.
Correct Answer by AFROJ AHMAD about 3 years 8 months ago
Hi ,
check the attched screen shot and look for the same settings..
Thanks-
Afroz
[Do rate the useful post]
Overall Rating: 5 (1 ratings)
SpongeRob Thu, 12/19/2013 - 05:50
...it had potential, however the only thing to display are the wireless controllers.  ALL was selected and it onlyu displays the WCs.  What say you ?
Marvin Rhoads Thu, 12/19/2013 - 06:43
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
My Prime 2.0 shows my switches along with the WLC when configured per Afroz's suggestion.
SpongeRob Thu, 12/19/2013 - 07:03
Thanks - it should be that simple - it actually had until the server was reloaded, all services are up.  I'll speak with TAC
